Старый 10.08.2016, 02:11   #1
emeadaxsupport: You receive the error: “One or more items associated with this Item model group are controlled by processes defined for warehouse management and the use of reservation hierarchy. FIFO date-controlled reservations will not be used for
Источник: https://blogs.msdn.microsoft.com/axs...te-controlled/
If you have the “FIFO date-controlled” option marked on the Item model group and the “Use warehouse management processes” option marked on the Storage dimension group, it would be working as designed that you are receiving this error as you cannot use the two of these options together. To verify if these options are marked,... Read more
Часовой пояс GMT +3, время: 03:42.
