Старый 23.06.2016, 18:11   #1
jaestevan: Unit Testing X++ code in Visual Studio (AX 2012) [EN]
Источник: http://www.jaestevan.com/unit-testin...dio-ax-2012-en
I’m pretty sure everybody who has tried will agree with me that the Unit Testing framework included in the AX 2012 development environment (aka MorphX) has some limitations. Sometimes such limits become so impacting that makes the framework almost useless when the code you need to test starts growing (let’s discuss design problems in a separate post :)).
But I’m not going to talk here about limitations, but about what we actually can do, and one of such things is to use X++ proxy classes to write our unit tests in Visual Studio, and use the native testing framework included here with all its possibilities. Let’s see how it works with an easy example.
I wrote this simple X++ class in order to have something to test:
/// Dummy fluid class for testing purposes
class DEVDummyTestCalcClass
real value;
public void new(real _value)
value = _value;
public real Value()
return value;
public DEVDummyTestCalcClass Add(real _value)
return new DEVDummyTestCalcClass(value + _value);
public DEVDummyTestCalcClass Substract(real _value)
return new DEVDummyTestCalcClass(value - _value);
public DEVDummyTestCalcClass Multiply(real _value)
return new DEVDummyTestCalcClass(value * _value);
public DEVDummyTestCalcClass Divide(real _value)
return new DEVDummyTestCalcClass(value / _value);
First of all, go to the Visual Studio 2010 instance we all have in our AX 2012 development environments and create a new Test Project. (I’ve chosen C# but it should work in Visual Basic if that’s your preferred choice):
Add this new project to AOT. By doing so, Visual Studio will add the Interop assembly to the project, allowing us to run our X++ code from this CIL project, automatically creating all needed proxy classes:
Show the Application Explorer panel so we can see AOT objects from the Visual Studio editor:
Choose the class (or classes) you want to test and add them to the project. This will automatically create all required proxy classes:
Now remove the TestMethod1 method in the default class or create your own test classes at your convenience. For instance, for testing the X++ simple class shown above, we can write some test methods like these ones:
[TestMethod]
public void TestConstruct()
using (Session axSession = new Session())
axSession.Logon(null, null, null, null);
Assert.AreEqual(0, new DEVDummyTestCalcClass(0).Value());
Assert.AreEqual(-1, new DEVDummyTestCalcClass(-1).Value());
[TestMethod]
public void TestSum()
Assert.AreEqual(10, new DEVDummyTestCalcClass(0).Add(10).Value());
Assert.AreEqual(10, new DEVDummyTestCalcClass(0).Add(5).Add(5).Value());
[TestMethod]
public void TestDivide()
Assert.AreEqual(10, new DEVDummyTestCalcClass(20).Divide(2).Value());
[TestMethod]
[ExpectedException(typeof(Microsoft.Dynamics.AX.ManagedInterop.NumericException))]
public void TestDivideByZeroException()
new DEVDummyTestCalcClass(100).Divide(0).Value(); // Exception
Finally, we can run our test cases as a regular Visual Studio test project, to be sure our X++ class works as expected:
How cool is that? Isn’t it easy?
If this is an interesting topic I’ll publish more about it, including more complicated and close-to-real scenarios. In the meantime, please feel free to comment or get in touch via twitter!
emeadaxsupport: What Visual Studio Source Control > Plug-in selection, when using TFS as Dynamics AX 2012 Version Control System? Blog bot DAX Blogs 0 25.03.2015 13:11
emeadaxsupport: Visual Studio Tools for Microsoft Dynamics AX 2012 R3 CU8 now requires Microsoft Visual Studio 2013 Blog bot DAX Blogs 0 25.11.2014 00:12
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
axinthefield: Compatibility Testing for Microsoft Dynamics AX Blog bot DAX Blogs 0 23.06.2012 02:26
Часовой пояс GMT +3, время: 22:48.
