It does compile without errors. But does it also run without errors?
datshipmentdate := 01072012D; intDateDec := 9999; intDateDec := (CREATEDATETIME(”datShipmentdate”, 0T) - CREATEDATETIME(010180D, 0T)) / 86400000; MESSAGE(’%1′,intDateDec); I’ll give the SQL answer (even if SQL has nothing to do with it): it depends. It works on 4.0SP3 Build 25638,5.0SP1 Build 26084. It gives an error on 5.0SP1 Build 30488,NAV2009 build 27808,NAV2009SP1 build 29227,NAV2009R2 32228 The error is: Overflow under type conversion of Decimal to Integer. Value: 11,869.9583333333333 Other builds I didn’t try, but it is clear that between builds 26084 and 30488 something has changed internally in C/AL. In the older versions, the result is implicitly converted to an integer but not anymore in the newer versions. These are 2 versions that work: datshipmentdate := 01072012D; intDateDec := 9999; intDateDec := ROUND((CREATEDATETIME(”datShipmentdate”, 0T) - CREATEDATETIME(010180D, 0T)) / 86400000,1); MESSAGE(’%1′,intDateDec); or also: datshipmentdate := 01072012D; intDateDec := 9999; intDateDec := (CREATEDATETIME(”datShipmentdate”, 0T) - CREATEDATETIME(010180D, 0T)) DIV 86400000; MESSAGE(’%1′,intDateDec); Читать дальше
