Старый 14.04.2008, 14:18   #2
Bulk Inserts is a new feature in NAV 5.0 SP1 which is designed to improve performance when inserting multiple records by delaying the physical inserts on the SQL Server. Before this change, inserts happen in the order that the C/AL code is running. With Bulk Insert, the NAV-client delays the actual inserts until the last possible moment in the transaction. This means that tables get locked later, so it reduces the amount of time that a table is locked. "The last possible moment", means...(read more)
Подробнее... http://dynamicsuser.net/blogs/navsustatine...av-5-0-sp1.aspx
Часовой пояс GMT +3, время: 02:17.
