Старый 31.03.2016, 23:12   #1
Date valid fields in View and AOT Query
Источник: http://alexvoy.blogspot.com/2016/03/...aot-query.html
Unfortunately, I did not manage to select addresses effective as of today from the DirPartyPostalAddressView view.
Nevertherless, its ValidTimeStateEnabled property set to Yes.
My workaround is to use SysQueryRangeUtil class providing greaterThanUtcNow and lessThanUtcNow methods to create an extended range. So my Query looks like the following.
axblog4u: Address/Contact Information: Export data using View in AX 2012 Blog bot DAX Blogs 0 01.05.2014 13:11
axblog4u: Address/Contact Information: Export data using View in AX 2012 Blog bot DAX Blogs 0 29.01.2014 16:11
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
xplusplus: Dynamics AX Application Object Tree (AOT) Blog bot DAX Blogs 0 25.11.2010 18:11
C# and AX Development: AOS crashed due corrupted node in the AOT Blog bot DAX Blogs 3 29.06.2009 15:14
Часовой пояс GMT +3, время: 10:02.
