Старый 03.08.2015, 18:43   #3
Kabardian is offline
Kabardian
Талантливый разгвоздяй
Аватар для Kabardian
424 / 338 (12) ++++++
Записей в блоге: 14
Хотфикс выше неправильный - при тестировании была обнаружена ошибка. Рабочий вариант исправления:
        if (lastInvoiceId != transTable.invoiceId)
            postCreditLedgerJournalLine();
            // Unblock the customer
            custUnblocker.unblockCustomer(transTable.custAccount);
            select sum(grossAmount), sum(paymentAmount) from transTable2
                group by store, businessDate, custAccount, currency, exchRate, invoiceId
                where  transTable2.statementId == statementTable.statementId
                    && transTable2.invoiceId == transTable.invoiceId
                    && transTable2.type != RetailTransactionType::Logoff
                    && transTable2.type != RetailTransactionType::Logon
                    && transTable2.type != RetailTransactionType::Payment
                    && transTable2.type != RetailTransactionType::CustomerOrder
                    && transTable2.type != RetailTransactionType::PendingSalesOrder
                    && !transTable2.incomeExpenseAmount
                    && !transTable2.salesInvoiceAmount
                    && !transTable2.salesOrderAmount;
            custTable = CustTable::find(transTable.custAccount);
            if (custTable.InvoiceAccount)
                invoiceAccount = custTable.InvoiceAccount;
            else
                invoiceAccount = custTable.AccountNum;
            // <GEERU>
            if (correspondenceEnabled)
                offsetAccountNum = RetailStatementPaymentJournal::getNativeNonLedgerAccount(invoiceAccount, LedgerJournalACType::Cust);
            // </GEERU>
            totalRoundAmountCur = this.postRoundingDifference(transTable2
                                                              // <GEERU>
                                                              , offsetAccountNum
                                                              // </GEERU>
emeadaxsupport: [AX 2012 R3] Why is my Kernel build version not changing after installing CU-8 or the latest binary hotfix? Blog bot DAX Blogs 0 31.12.2014 20:20
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2012 R3 RTM Warehouse Management: How to prevent the creation of two inventDim records considered identical in Dynamics AX 2012 R3 RTM Blog bot DAX Blogs 0 22.12.2014 19:12
Часовой пояс GMT +3, время: 14:52.
