Старый 02.06.2015, 13:11   #1
sashanazarov: Which query range should I select?!
Источник: http://sashanazarov.blogspot.com/201...-i-select.html
Customer asked me to figure out which "Customer account" should be selected in a query. There were three of them on the Customer invoice journal table:
Apparently, there were a couple of fields that used the default label, and I found them in the following way.
Selected the first "Customer account" range:
... right-clicked in the field value and selected Record Info:
... in the dialog, clicked on the Script button:
... pasted the clipboard to Notepad:
The extended field ID was 65540.
Then, I selected another range:
... and repeated the process. The second field ID was 81625. Finally, I selected the third Customer account range and found that it was based on the field ID 81626.
So, the three field IDs for CustInvoiceJour table were found. But what were the field names?
static void printFieldNames(Args _args)
print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(65540));
print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(81625));
print fieldId2Name(tableNum(CustInvoiceJour), fieldExt2Id(81626));
pause;
And the output was:
Somebody did not follow the Best Practices for Table Fields:
Старый 02.06.2015, 19:56   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Эти поляки!
За это сообщение автора поблагодарили: Stitch_MS (0).
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 5 Blog bot DAX Blogs 0 01.09.2014 14:11
Ax 2012. Копирование Range из Query Sada DAX: Программирование 2 22.08.2013 10:10
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Часовой пояс GMT +3, время: 12:38.
