emeadaxsupport: Unable to insert data into the Channel database - String or Binary data would be truncated
Источник: http://blogs.msdn.com/b/axsupport/ar...truncated.aspx
============== Dynamics AX 2012 R2/R3 Retail Description: While inserting a Distribution package job like 1010 into the Channel database following message appears and the operation stops. Full error message: Microsoft.Dynamics.Retail.StoreConnect.Request.SQLHandler.ProcessSourceRequestHeaderException: ProcessTargetRequestHeader failed due to an InvalidOperationException. connectionString: Data Source=743R1;Initial Catalog=POSDB;Integrated Security=True;MultipleActiveResultSets=True;Connect Timeout=60;Encrypt=True;TrustServerCertificate=True;Application Name="Commerce Data Exchange Async Client" ---> System.InvalidOperationException: The given value of type String from the data source cannot be converted to type nvarchar of the specified target column. ---> System.InvalidOperationException: String or binary data would be truncated. at System.Data.SqlClient.SqlBulkCopy.ConvertValue(Object value, _SqlMetaData metadata, Boolean isNull, Boolean& isSqlType, Boolean& coercedToDataFeed) --- End of inner exception stack trace --- How to troubleshoot the issue: The message “String and Binary data would betruncated”, means that the data length of a string is longer than accepted by the field. Validate which field is longer than accepted by
Result: The result shows us that the Dirparytable NameAlias has a record that is 45 characters in length in the AX database, but only 20 characters are allowed in the channel database. tableName ColumnName CHANNELLEN HQMAXLEN DIRPARTYTABLE NAMEALIAS 20 45 NUMBERSEQUENCETABLE TXT 30 35 BARCODESETUP DESCRIPTION 30 26 RETAILTENDERTYPETABLE NAME 30 23 RETAILSIZEGROUPTABLE DESCRIPTION 30 22 INVENTMODELGROUP NAME 30 16 RETAILSTYLEGROUPTABLE DESCRIPTION 30 15 CASHDISC DESCRIPTION 30 11 The solution:
Author: Kim Truelsen Date: 15/5-2015 Источник: http://blogs.msdn.com/b/axsupport/ar...truncated.aspx
