Zurück   AXForum > Microsoft Dynamics AX > DAX: База знаний и проекты
Kennwort vergessen?
Registrieren Forum Rules Hilfe Benutzerliste Heutige Beiträge Suchen
Themen-Optionen Thema durchsuchen Ansicht
Alt 13.01.2015, 15:54   #1
Vadik ist offline
Vadik
Benutzerbild von Vadik
3.631 / 1853 (69) ++++++++
KB 3023315"User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)" error when adding a record through Application Integration Framework (AIF) for a non-ad
Для тех кто активно использует AIF с AX 2012
KB 3023315 "User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)" error when adding a record through Application Integration Framework (AIF) for a non-admin user
PROBLEM
When adding a record through Application Integration Framework (AIF) for a non-admin user, you receive the following error message:
"User is not authorized to insert a record in table 'SYSDATABASELOG'. Request denied. Cannot create a record in Database log (SysDataBaseLog)."
DESCRIPTION OF CHANGE
The changes in the hotfix include skipping the permission check if the database log operation is from kernel.
-ТСЯ или -ТЬСЯ ?
This post has been rated by: gl00mie (3).
Stichworte
aif, ax2012, hotfix, sysdatabaselog, журнал базы данных
Ähnliche Themen
Thema Autor Forum Antworten Letzter Beitrag
emeadaxsupport: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId". The conflict occurred in database "YourDataBaseName_model", table "dbo.Model" Blog bot DAX Blogs 0 23.05.2014 13:11
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Forumregeln
Es ist Ihnen nicht erlaubt, neue Themen zu verfassen.
Es ist Ihnen nicht erlaubt, auf Beiträge zu antworten.
Es ist Ihnen nicht erlaubt, Anhänge hochzuladen.
Es ist Ihnen nicht erlaubt, Ihre Beiträge zu bearbeiten.
BB-Code ist an.
Smileys sind an.
[IMG] Code ist an.
HTML-Code ist aus.
Gehe zu
Alle Zeitangaben in WEZ +3. Es ist jetzt 20:37 Uhr.
Powered by vBulletin® Version 3.8.5 (Deutsch)
Copyright ©2000 - 2025, Jelsoft Enterprises Ltd.
