Старый 26.06.2014, 21:53   #6
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
Еще одно решение. Подглядел идею в \Classes\SysStartupCmdBuildVisualStudioProjects
Немного подкорректировал:
/// <summary>
/// Builds a <c>Set</c> object containing node paths to the SSRS Reports that the project references.
/// </summary>
/// <param name="projectNode">
/// The <c>VSProjectNode</c> object.
/// </param>
/// <returns>
/// A <c>Set</c> object containing node paths to the SSRS Reports that the project references.
/// </returns>
private Set getVSProjectNodeReportReferences(VSProjectNode projectNode, str _ssrsName)
    Set reportReferences = new Set(Types::String);
    VSProjectFileNode projectFileNode;
    str source, xpath, reportReference;
    int pos, len;
    System.IO.StringReader reader;
    System.Xml.XPath.XPathDocument doc;
    System.Xml.XPath.XPathNavigator navigator, nodeNavigator;
    System.Xml.XPath.XPathExpression expression;
    System.Xml.XPath.XPathNodeIterator nodeIterator;
    System.Xml.XmlNamespaceManager namespaceManager;
    // check for the Project node, the Project Content node and a project file node
    if (projectNode && projectNode.aoTfirstChild() && projectNode.aoTfirstChild().AOTfirstChild())
        projectFileNode = projectNode.aoTfirstChild().AOTfirstChild();
        source = projectFileNode.AOTgetSource();
        len = strLen(source);
        if (len)
            // remove any unwanted characters from the beginning of the string
            pos = strFind(source, @"<", 1, len);
            if (source && pos)
                source = subStr(source, pos, len);
            if (source)
                // load the source into an XPathDocument object and find all report references using xpath select
                reader = new System.IO.StringReader(source);
                doc = new System.Xml.XPath.XPathDocument(reader);
                navigator = doc.CreateNavigator();
                namespaceManager = new System.Xml.XmlNamespaceManager(navigator.get_NameTable());
                namespaceManager.AddNamespace(@"msbuild", @"http://schemas.microsoft.com/developer/msbuild/2003");
                xpath = @"//msbuild:Project/msbuild:ItemGroup/msbuild:Compile/@Include";
                expression = System.Xml.XPath.XPathExpression::Compile(xpath);
                expression.SetContext(namespaceManager);
                nodeIterator = navigator.Select(expression);
                if (nodeIterator)
                    while (nodeIterator.MoveNext())
                        nodeNavigator = nodeIterator.get_Current();
                        reportReference = nodeNavigator.get_Value();
                        if (reportReference && reportReference == _ssrsName)
                            reportReferences.add(reportReference);
    return reportReferences;
/// <summary>
/// Builds a <c>Map</c> object that whose key is a <c>VSProjectNode</c> object and value is a <c>Set</c> object
/// containing the AOT node paths of the SSRS Reports the project references.
/// </summary>
private void buildDynamicsAXModelProjectToReportsMap(str _ssrsName)
    TreeNode treeNode;
    VSProjectNode projectNode;
    Set reportSet;
    // Key is VSProjectNode
    // Value is Set of strings - AOT paths to the SSRS reports used in the project
//    dynamicsAXModelProjectToReportsMap = new Map(Types::Class, Types::Class);
    treeNode = TreeNode::findNode(#VSProjectsAXModelPath);
    if (treeNode)
        projectNode = treeNode.AOTfirstChild();
        while (projectNode)
            reportSet = this.getVSProjectNodeReportReferences(projectNode, _ssrsName);
            if (reportSet && reportSet.elements() > 0)
                info(projectNode.name());
//                dynamicsAXModelProjectToReportsMap.insert(projectNode, reportSet);
            projectNode = projectNode.aoTnextSibling();
Вызов:
    this.buildDynamicsAXModelProjectToReportsMap(#SSRSReportsPath + '\\' + 'VendInvoice');
За это сообщение автора поблагодарили: mazzy (5), trud (3).
i-neti: В VS не показываются новые поля временной таблицы SSRS-отчета Blog bot DAX Blogs 0 18.06.2014 17:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Работа отчета "Отчет об анализе расхождений"(InventCostVariances) irvin DAX: Программирование 3 19.08.2013 15:01
AX2012 корректная инициализация параметров отчета (SSRS) PavelX DAX: Программирование 1 24.11.2012 18:48
Часовой пояс GMT +3, время: 13:19.
