Старый 05.02.2014, 04:16   #1
mscrmblog: Disable SharePoint Authentication prompts for Office Documents
Источник: http://mscrmblog.net/2014/02/04/disa...e-documents-2/
Depending on your setup, users will at times receive an authentication prompt when opening Microsoft office documents even when the site is in the Trusted Sites list or the Intranet sites list. There are reasons for this which are complex but you may have a good read of the KB article: http://support.microsoft.com/kb/838028
The fix is to modify the SharePoint web application config file (web.config) in the app directory to specifically bypass the authentication prompts. As a rule of thumb, please backup your web.config before making any changes.
mscrmblog: Disable SharePoint Authentication prompts for Office Documents Blog bot Dynamics CRM: Blogs 0 04.02.2014 08:12
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
crminthefield: Script errors when adding documents via the SharePoint integration CRM UR12+ Blog bot Dynamics CRM: Blogs 0 07.08.2013 01:12
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
mscrmblog: SharePoint 2010 Developer Dashboard Blog bot Dynamics CRM: Blogs 0 11.07.2011 03:18
Часовой пояс GMT +3, время: 22:17.
