Pawan's Ax blog: How To Iterate all the fields of a table in Ax2012 using x++ code.
Источник: http://pawansaxblog.blogspot.com/201...-table-in.html
============== In my recent implementation I was having one requirement in this I had to retrieve all the fields of a table and then on certain criteria I had to update these fields in another table. I could do this sing If-else condition but it requires lot of code. So I did it in a better way. public void updateEstimatesFromCase() { CopyEstimates copyEstimates; SysDictTable dictTable; SysDictTable caseDictTable; SysDictTable activityDictTable; SysDictField dictField; SysDictField caseDictField; SysDictField activityDictField; FieldId fieldId; FieldId caseFieldId; FieldId activityFieldId; CaseDetailBase caseDetailBase = caseDetailBase::find(this.caseId()); CaseTimeEstimatesTable caseTimeEstimatesTable; ActivityTimeEstimatesTable activityTimeEstimatesTable; ActivityTimeEstimatesTable buffer; ; select firstonly caseTimeEstimatesTable where caseTimeEstimatesTable.CaseDetailBase == caseDetailBase.RecId; select firstOnly activityTimeEstimatesTable where activityTimeEstimatesTable.smmActivities == this.smmActivities; buf2Buf(buffer,activityTimeEstimatesTable); if (activityTimeEstimatesTable.RecId) { activityTimeEstimatesTable.selectForUpdate(true); activityTimeEstimatesTable.update(); } caseDictTable = new SysDictTable(caseTimeEstimatesTable.TableId); dictTable = new SysDictTable(this.TableId); fieldId = dictTable.fieldNext(0); while (fieldId) { dictField = dictTable.fieldObject(fieldId); if (dictField.isSql() && !dictField.isSystem()) { activityTimeEstimatesTable.smmActivities = this.smmActivities; if (this.(fieldId) && fieldId != fieldNum(copyEstimates, smmActivities)) { caseFieldId = fieldName2id(tableNum(CaseTimeEstimatesTable),dictField.name()); activityFieldId = fieldName2id(tableNum(ActivityTimeEstimatesTable),dictField.name()); activityTimeEstimatesTable.(activityFieldId) = caseTimeEstimatesTable.(caseFieldId); if (activityTimeEstimatesTable.RecId) { activityTimeEstimatesTable.selectForUpdate(true); activityTimeEstimatesTable.update(); } else { activityTimeEstimatesTable.insert(); } } } fieldId = dictTable.fieldNext(fieldId); } } Источник: http://pawansaxblog.blogspot.com/201...-table-in.html
