Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.12.2013, 13:08   #9
ist is offline
ist
Сообщение от Alex_KD Посмотреть сообщение
Hi ist,
Have you tried to put your AIF call code inside try-catch statement and get the whole Exception in VS debugger?
Also, what are you passing as the first parameter in AIF methods (CallContext)?
Alex
Hi Alex,
I don't use callContext, because the application pool for AIF web services is started with business connector user account (configured in Administration/Setup/Security/System service accounts). I have added business connector user in AX users and configured it's default company. If I want to work in a diferrent AX company I have to change default company for business connector user.
Regards,
aif
daxdilip: Fiddler - Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
axaptasource: Fiddler – Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Arijit Basu: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 04.05.2008 23:05
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 05:45.
