Старый 18.12.2013, 11:40   #1
Ruff is offline
Ruff
Дмитрий Ерин
Аватар для Ruff
1C
475 / 396 (14) ++++++
А можно вот так (в порядке тренировки навыков работы с XSLT):
static void ResearchXSLT(Args _args)
    #define.OldValue("value")
    #define.NewValue("NewValue")
    str fileName = "C:\\temp\\1.xml";
    str xslt = strFmt('<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">'+
        '<xsl:template match="*|@*|text()">'+
        '<xsl:copy>'+
        '<xsl:apply-templates select="*|@*|text()"/>'+
        '</xsl:copy>'+
        '</xsl:template>'+
        '<xsl:template match="@atribut[.=\'%1\']">' +
        '<xsl:attribute name="atribut">%2</xsl:attribute> '+
        '</xsl:template>'+
        '</xsl:stylesheet>',
        #OldValue,
        #NewValue);
    str outXml = '';
    System.Xml.XmlReader                xslReader;
    System.Xml.XmlReader                xmlReader;
    System.Xml.XmlTextWriter            xmlWriter;
    System.IO.StringReader              stringReader;
    System.IO.StringWriter              stringWriter;
    System.Xml.Xsl.XslCompiledTransform xslTransform;
    System.IO.StreamWriter              streamWriter;
    new InteropPermission(InteropKind::ClrInterop).assert();
    info(xslt);
    stringReader    = new System.IO.StringReader(xslt);
    xslReader       = System.Xml.XmlReader::Create(stringReader);
    xmlReader       = System.Xml.XmlReader::Create(fileName);
    xslTransform    = new System.Xml.Xsl.XslCompiledTransform();
    xslTransform.Load(xslReader);
    stringWriter    = new System.IO.StringWriter();
    xmlWriter       = new System.Xml.XmlTextWriter(stringWriter);
    xslTransform.Transform(xmlReader, xmlWriter);
    xmlReader.Close();
    xmlWriter.Close();
    outXml = stringWriter.ToString();
    streamWriter    = new System.IO.StreamWriter(fileName);
    streamWriter.Write(outXml);
    streamWriter.Close();
    CodeAccessPermission::revertAssert();
    info(outXml);
Старый 21.12.2013, 15:19   #2
Cardagant is offline
Cardagant
317 / 54 (2) ++++
В дополнение к примеру b_nosoff выложу свой, возможно, будет полезен
#define.text2('text2')
#define.Atribut('atribut')
#define.path(@"Your file path")
XMLDocument             xmlDoc;
XmlElement              xmlNode;
XmlNodeList             xmlNodeList;
XMLAttribute            attribute;
xmlDoc      = XMLDocument::newFile(#path);
xmlNodeList = xmlDoc.getElementsByTagName(#text2);
for (xmlNode = xmlNodeList.nextNode(); xmlNode != null;
     xmlNode = xmlNodeList.nextNode())
    attribute = xmlNode.getAttributeNode(#Atribut);
    if (attribute)
       attribute.text('New value');
xmlDoc.save(#path);
attribute, xml, xmldocument, атрибут
Перевод строки в xml-файле Ivanhoe DAX: Программирование 48 13.02.2012 12:54
kamalblogs: Converting a System.Xml.XmlDocument to XML type in Dynamics ax Blog bot DAX Blogs 0 19.04.2010 09:05
X++: Serializing Axapta Foundation Class instances as XML streams Blog bot DAX Blogs 0 04.06.2009 23:05
PatrickChua: XML serialization Blog bot DAX Blogs 0 04.05.2009 14:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Часовой пояс GMT +3, время: 01:39.
