Старый 05.08.2013, 10:17   #9
Dreadlock is offline
Dreadlock
Аватар для Dreadlock
298 / 224 (8) ++++++
Вот как бы с этим разобраться в каких случаях что именно нужно делать?
Refreshing Caches
Enterprise Portal caches resources from the AOT and data from tables in Microsoft Dynamics AX. If you make changes in the AOT, the changes may not be reflected immediately in Enterprise Portal. In a similar way, data that has been changed in tables for Microsoft Dynamics AX may not immediately be seen in Enterprise Portal. Stale data in these caches could cause unexpected results in Enterprise Portal. Three commands are available in the Administration group at the bottom of the main page for Enterprise Portal to refresh these caches. The commands are described in the following table.
Refresh AOD - Flushes cached application object information for all items in the AOT. Use this when changes you made in the AOT are not immediately reflected in Enterprise Portal.
Refresh data - Flushes cached database records. Use this when changes in the database are not immediately reflected in Enterprise Portal.
Refresh dictionary - Flushes cached application object information for items in the Data Dictionary node of the AOT. Use this when you have made changes to resources in the Data Dictionary node, such as tables or extended data types, but the changes are not immediately reflected in Enterprise Portal.
источник
Итератор с поддержкой методов обратного вызова для обработки контролов на форме gl00mie DAX: Программирование 18 06.08.2013 22:16
Dynamics AX Sustained Engineering: Individual patching for Dynamics AX2009 SP1 industry solutions Blog bot DAX Blogs 0 13.06.2012 10:11
dynamicscare: Understanding Production Postings in AX2009 Blog bot DAX Blogs 0 26.08.2011 21:13
axinthefield: Choosing a Single Deployment or Multiple Deployments of AX2009 Blog bot DAX Blogs 0 15.06.2011 03:25
Shekhar: Dynamics AX2009 : Standalone Installation on Vista with Role centres and workflow. Blog bot DAX Blogs 0 30.03.2010 15:05
Часовой пояс GMT +3, время: 07:50.
