|  14.12.2012, 23:11 | #1 |
| Участник | ax-erp: EDT Relation Migration Tool [AX 2012]
			Источник: http://microsoft-dynamics-ax-erp.blo...l-ax-2012.html ============== Updated: May 18, 2011 Applies To: Microsoft Dynamics AX 2012 R2, Microsoft Dynamics AX 2012 Feature Pack, Microsoft Dynamics AX 2012 In Microsoft Dynamics AX 2012, relations can no longer be created under extended data type (EDT) nodes in the Application Object Tree (AOT). Relations that are defined under EDT nodes are still effective, but in a future release they will be obsolete and deleted. The EDT relation migration tool helps you move relations from EDT nodes to table nodes. The EDT relation migration tool is found on the client menu, under Tools > Code upgrade > EDT relation migration tool. The Representation of Relations Before Microsoft Dynamics AX 2012, relations could be defined under the Relations node of an EDT node, or under a table node. The following table describes the differences between how relations were handled in Microsoft Dynamics AX 2009 and how relations are handled in Microsoft Dynamics AX 2012. Microsoft Dynamics AX 2009 Microsoft Dynamics AX 2012 Both table and EDT relations were supported. EDT relations could not contain metadata such as cardinality and relation type. New EDT relations cannot be created. Use table relations instead. Table relations can contain metadata. Table relations could not be used for dynamic links. Table relations now support dynamic links. Table relations could not be used for unbound control lookup. Table relations now support unbound control lookup. Having both types of relations on a single table could introduce ordering problems in certain circumstances. New EDT relations cannot be created. We recommend that you convert all existing EDT relations to table relations. To preserve existing behavior, a new property that is named Reference Table has been added to the EDT structure. Each EDT node in the AOT contains a new Table References node that stores lookup information. Using the EDT Relation Migration Tool When you first start the EDT relation migration tool, a message may be displayed: The data on existing EDT relations needs to be refreshed. Do you want to continue?Click Yes to refresh the list of EDT relations. Automating the Migration Process You can use the EDT relation migration tool to help you complete the migration process. The tool can perform the following actions:
 Navigating the Form The following figure displays the EDT relation migration tool.  The EDT relation migration tool, displaying the EDT relations for the WrkCtrTable The left pane displays a list of tables that contain EDT relations. When you select a table in the left pane, the right pane displays the metadata of the selected table that may be affected by the migration. The following items describe how to navigate the form:
 Controls in the Form The following tables provide descriptions for the controls in this form. Left Side Pane List Description Table name The tables that use EDT relations. Right Side Pane FastTab Description EDT relations View the list of EDT relations that are used by the selected table. Relation properties View the properties of the selected EDT relation. Affected delete action View whether the EDT relation is used in a delete action of the table. Affected forms View the forms that are affected by this relation. Affected queries View the queries that are affected by this relation. Affected data sets View the data sets that are affected by this relation. Affected X++ reports View the X++ reports that are affected by this relation. Menu Actions Action Description Refresh relation data Refresh the relation data. Scan test artifacts Scan the test artifacts. Migrate multiple tables Migrate the selected tables. More than one table must be selected. Otherwise, this action is not available. Migrate single table Migrate the selected table. Only one table can be selected. Otherwise, this action is not available. Buttons Button Description Migrate all Set the Migration action field to Migrate for every relation for which the Migration status field is set to Not migrated. Источник: http://microsoft-dynamics-ax-erp.blo...l-ax-2012.html
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
