Старый 08.10.2012, 10:10   #1
Poleax is offline
Poleax
Модератор
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Дополню:
см. http://www.axaptapedia.com/Dynamics_...allation#AOS_2
см. http://dynamics-ax-live.blogspot.com...er-system.html
Error: Cannot create another system semaphore
When trying to start the Dynamics Ax AOS service, the attempt fails.
You may receive following error message:
When you check the Windows event log, you may come across following error:
Fatal SQL condition during login.
Probable causes:
  1. The SQL Server service is down, verify this first.
  2. The account that has been setup to start the AOS service, does not have the proper security rights for the Ax SQL database.
Regarding number 2:
If you copy your database from one environment to another (from Production to Test for example), make sure you have the right security setup in place. Does the startup account used for the AOS service have access to the SQL database?
Once the account has access, make sure it has proper access.
If you don't want to give it the db_owner role, make sure at least following roles are assigned to the service account
• db_ddladmin
• db_datareader
• db_datawriter
Also make sure permission to execute both stored procedures is in place.
After you verified the above, you should be able to start the AOS service.
AX 2009: зачем нужен балансировщик нагрузки, и как в кластере зайти на определенный AOS? gl00mie DAX: Администрирование 7 26.02.2015 16:38
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Проблемы c тонким клиентом и AOS TrY DAX: Администрирование 7 25.02.2004 11:38
Часовой пояс GMT +3, время: 09:14.
