var config = new ServerConnection.Configuration();
//config.DiscoveryUri = new Uri("https://Organization.crm.dynamics.com/XRMServices/2011/Discovery.svc"); config.DeviceCredentials = DeviceIdManager.LoadDeviceCredentials(); //GetDeviceCredentials(); config.OrganizationUri = new Uri("https://Organization.api.crm4.dynamics.com/XRMServices/2011/Organization.svc"); config.Credentials = new ClientCredentials(); config.Credentials.UserName.UserName = "MyName"; config.Credentials.UserName.Password = "MyPassword"; config.HomeRealmUri = null; //if (configurations == null) configurations = new List<ServerConnection.Configuration>(); //configurations.Add(config); // return config; _serviceProxy = new OrganizationServiceProxy(config.OrganizationUri, config.HomeRealmUri, config.Credentials, config.DeviceCredentials); Service = (IOrganizationService)_serviceProxy ; var contact= Service.Retrieve("contact", new Guid("C2ED8E8E-F3F1-E111-89CB-B499BAFE021B"), new ColumnSet(true)); |
Чайный пьяница
У меня заработал следующий код:
Код: ClientCredentials credentials = new ClientCredentials(); credentials.UserName.UserName = {User Name}; credentials.UserName.Password = {Password}; var _serviceProxy = new OrganizationServiceProxy(new Uri("https://{OrgName}.api.crm4.dynamics.com/XrmServices/2011/Organization.svc"), null, credentials, GetDeviceCredentials()); _serviceProxy.Timeout = new TimeSpan(1, 0, 0); _serviceProxy.ServiceConfiguration.CurrentServiceEndpoint.Behaviors.Add(new ProxyTypesBehavior()); //Операции по вызову сервиса Код: private static ClientCredentials GetDeviceCredentials() { return Microsoft.Crm.Services.Utility.DeviceIdManager.LoadOrRegisterDevice(); }
У меня все равно неработает. Могу дать свои креденшилы для теста. Если несложно можете попробовать залезть
UserName = "132@nvovka.onmicrosoft.com"; Password = "nhfycthabyu@123"; https://nvovka.api.crm4.dynamics.com...ganization.svc Device.UserName = "11sc4mkqbp01mleopmmn8czuap"; Device.Password = "b9C.sxoVQ67/OptmzrYg@MeQ"; Выполняю етот простой запрос var contact= Service.Retrieve("contact", new Guid("C2ED8E8E-F3F1-E111-89CB-B499BAFE021B"), new ColumnSet(true)); Данные с етим ИД есть |
#4 |
Чайный пьяница
Очень странно. Я даже попробовал эту библиотеку - http://connectioncontrol.codeplex.com/
Даже с ней не получается подключиться. Связался с автором тула. Возможно он поможет.
#5 |
Возможно это все таки trial? Много лазил искал по етому поводу многие немогут законектится. А вы сами когда конектились у вас trial CRM online?
#6 |
Чайный пьяница
Пробовал одну промсреду.
За это сообщение автора поблагодарили: Nvovka (1). |
#7 |
Чайный пьяница
Ларчик просто открывался. Скачайте последнее SDK и сипользуйте в проекте сборки из неё. У меня всё заработало сразу.
