Под рукой только 2009. Смотрим указанный вами метод:
/// <summary>
/// Makes a query in order to find used coverage dimensions for an item. В классе есть отдельный метод calcDemandPeriod() в котором следующие комменты: Цитата:
/// Demand is calculated as issues in the specified period. However not all issues should be included in the calculation.
/// Issues having a corresponding receipt on the same coverage dimension should not be included. ... // find demand - internal transfers must not count as demand // internal transfer means that the issue and receipt has same coverage dimensions. // if warehouse isn't a coverage dimension then don't count transfer orders as demand
Ivanhoe as is.. |
| За это сообщение автора поблагодарили: Starling (2). | |
