#10 |
Чайный пьяница
Сообщение от kh_heckfy
ну поменял код и импортировал решение...
а ошибка в проге X++: Ribbon Workbench Exception Report: Version=1.0.0.259 Type:FaultException`1 Message:The solution cannot be imported because the businessunit entity contains a Ribbon definition, which is not supported for that entity. Remove the RibbonDiffXml node from the entity definition and try to import again. StackTrace: System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc) System.ServiceModel.Channels.ServiceChannel.EndCall(String action, Object[] outs, IAsyncResult result) System.ServiceModel.ClientBase`1.ChannelBase`1.EndInvoke(String methodName, Object[] args, IAsyncResult result) OrganizationServiceClient.OrganizationServiceClientChannel.EndExecute(IAsyncResult result) OrganizationServiceClient.IOrganizationService.EndExecute(IAsyncResult result) Develop1.Xrm.Silverlight.Ribbon.PublishSolutionController.OnCompletedImport(IAsyncResult asyncResult)
