Старый 19.04.2012, 15:36   #32
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Поле "К расчетно-платежному документу"
Последняя версия кода (для RU8 + KB 2677302):
\Data Dictionary\Tables\FactureJour_RU\Methods\document
server public container document()
    DocumentNum         docNum;
    DocumentDate        docDate;
    FactureTrans_RU     tmpFactureTrans;
    LedgerJournalTrans  ledgerJournalTrans;
    Set                 docNumSet = new Set(Types::String);
    switch (this.FactureType)
        case FactureType_RU::TaxCorrection   :
            if (this.vatTaxAgent && !this.DocumentNum && !this.DocumentDate)
                while select ledgerJournalTrans
                    group by DocumentDate, DocumentNum
                    join tmpFactureTrans
                        where tmpFactureTrans.MarkupRefRecId == ledgerJournalTrans.RecId &&
                              tmpFactureTrans.Module         == this.Module              &&
                              tmpFactureTrans.FactureId      == this.FactureId
                    docNumSet.add(ledgerJournalTrans.DocumentNum);
                    if (docNumSet.elements() > 1)
                        docNum  = '';
                        docDate = dateNull();
                        break;
                    docNum  = ledgerJournalTrans.DocumentNum;
                    docDate = ledgerJournalTrans.DocumentDate;
            break;
       // begin
       case FactureType_RU::Invoice:
            [docNum, docDate] = this. getPaymentInfo();
            break;
    return [ docNum, docDate ];
container getPaymentInfo()
    RecordSortedList    rst;
    CustVendInvoiceJour custVendInvoiceJour;
    CustVendTrans       custVendTrans, custVendTransPayment;
    CustVendSettlement  custVendSettlement;
    CustInvoiceJour     custInvoiceJour;
    VendInvoiceJour     vendInvoiceJour;
    CustTrans           custTrans, custTransPayment;
    VendTrans           vendTrans, vendTransPayment;
    CustSettlement      custSettlement;
    VendSettlement      vendSettlement;
    DocumentNum         docuNum;
    switch (this.Module)
        case FactureModule_RU::Cust :
            custVendInvoiceJour = custInvoiceJour;
            custVendTrans = custTrans;
            custVendTransPayment = custTransPayment;
            custVendSettlement = custSettlement;
            break;
        case FactureModule_RU::Vend :
            custVendInvoiceJour = vendInvoiceJour;
            custVendTrans = vendTrans;
            custVendTransPayment = vendTransPayment;
            custVendSettlement = vendSettlement;
            break;
        default                     :
            throw error(Error::wrongUseOfFunction(funcname()));
    rst = this.invoiceJourSortedList_CustVend();
    while (rst.next(custVendInvoiceJour))
        custVendTrans = custVendInvoiceJour.CustVendInvoiceJour::custVendTrans(custVendTrans);
        while select custVendSettlement
            where custVendSettlement.TransCompany   == custVendTrans.dataAreaId
               && custVendSettlement.TransRecId     == custVendTrans.RecId
               && custVendSettlement.AccountNum     == custVendTrans.AccountNum
            while select custVendTransPayment
               where custVendTransPayment.AccountNum    == custVendSettlement.AccountNum
                  && custVendTransPayment.Voucher       == custVendSettlement.OffsetTransVoucher
                  && custVendTransPayment.Recid         == custVendSettlement.OffsetRecid
                docuNum += ((docuNum ? ', ' : '') + custTransPayment.Txt);
                docDate = max(docDate, custTransPayment.TransDate);
    return [docuNum, docDate];
баг, локализация, накладная, ошибка, печатная форма, счет-фактура
Уникальный индекс в журнале накладных поставщиков Starling DAX: Программирование 11 14.03.2011 17:02
Расхождение функционала журнала одобрения накладных. PavelM DAX: Функционал 4 22.12.2005 19:03
Ax3.0 SP3 CIS: Журнал накладных и российские договора (ошибка) mpa DAX: Функционал 2 11.10.2004 15:14
Как включить контроль изменений в журнале накладных ? NEO DAX: Функционал 0 17.06.2004 12:30
Одобрение накладных Swetik DAX: Функционал 1 24.11.2003 14:53
Часовой пояс GMT +3, время: 06:19.
