workflowax: Adding code templates/shortcuts in AX 2012
Источник: http://workflowax.wordpress.com/2012/03/19/527/
============== If you’ve got any blocks of code that you use frequently, e.g. specific comment blocks, you can very easily add code short cuts in AX 2012 to auto-insert the them in to your X++ code. For example you can setup AX to automatically create surrounding comment such as ![]() whenever you type “mycom” and press the tab key. How do you accomplish this. Very easily! Step1: Locate the class EditorScripts in the AOT. Step2: Create a new method with the format public void template_flow_[shortcut](Editor editor) Step3: User the editor parameter to add code the code that you would like inserted. e.g. editor.insertLines(“\\test comment”); Step4: Add your method to the case statement in the isApplicableMethod method in the section relating to template “editor scripts that does not apply to Macros” ![]() Thats it, now if you type your shortcut into any editor in AX and press tab, the “\\test comment” code will be inserted. Here’s a full example method ![]() The above creates the following output: ![]() ![]() ![]() Источник: http://workflowax.wordpress.com/2012/03/19/527/
