Старый 12.03.2012, 11:11   #1
palleagermark: Preventing users from opening new workspaces
Источник: http://palleagermark.blogspot.com/20...ening-new.html
In AX 2009, before hotfix roll-up 6, AX has some issues when users open multiple workspaces with different company accounts.
I have seen issues where voucher numbers were pulled from the wrong company account and I have seen a data import going totally awry.
You can't completely prevent users from opening new workspaces through the security model, but you can add code that immediately closes these aging. Add the the following code to \Classes\Info\workspaceWindowCreated:
void workspaceWindowCreated(int _hWnd)
    // Put workspace window specific initialization here.
    // Begin -->
    if(xInfo::currentWorkspaceNum()>1)
        Infolog.shutDown(true);
    // End <--
Последний раз редактировалось Poleax; 12.03.2012 в 11:44. Причина: оформление
palleagermark: It is possible for users to edit the Item reference fields of sales order lines and purchase order lines. Blog bot DAX Blogs 0 17.02.2010 21:07
palleagermark: Convert an image from one format to another from AX Blog bot DAX Blogs 0 22.01.2010 15:05
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
palleagermark: Read data from other databases Blog bot DAX Blogs 5 11.06.2008 11:42
palleagermark: Spell checking from AX Blog bot DAX Blogs 0 04.04.2008 10:05
Часовой пояс GMT +3, время: 15:43.
