Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 05.03.2012, 10:18   #9
kaw is offline
kaw
Сообщение от ideveloper Посмотреть сообщение
We have a job to send a XML file to the customer per email.
Maybe, create AifFileSystemSendMailAdapter extends AifFileSystemAdapter
And into AifFileSystemSendAdapter.sendMessage – send Email partner
... and use the transformation abilities (after the answers here) of the outbound pipeline to map the XML mesasge into another schema.
I don't like this idea.
or configure “classes of the AIF to create” the XML Message required schema.
or use BizTalk
aif
emeadaxsupport: Cannot create Enterprise portal site with SharePoint 2010. Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml' Blog bot DAX Blogs 0 15.08.2011 23:11
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 19.10.2008 18:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dynamics AX FAQ: How to import and export data in XML format using AIF framework? Blog bot DAX Blogs 0 25.03.2008 03:58
Часовой пояс GMT +3, время: 16:35.
