#5 |
Скопировала библиотеку sample_/Scripts/SDK.REST.js к себе в solution и пытаюсь проапдейтить custom entity "steer_participant" аналогично тому, как приведено в примере http://technet.microsoft.com/en-us/l...taOperationsJS.
Но ничего не просиходит, что я делаю не так..? Код: function updateParticipant(ParticipantId) { var participant = {}; alert("Changing the participant status"); participant.steer_attended = true; SDK.REST.updateRecord( ParticipantId, participant, "steer_participant", function () { alert("The account record changes were saved"); deleteParticipant(ParticipantId); }, errorHandler ); } function deleteParticipant(ParticipantId) { if (confirm("Do you want to delete this account record?")) { writeMessage("You chose to delete the account record."); SDK.REST.deleteRecord( ParticipantId, "steer_participant", function () { writeMessage("The account was deleted."); enableResetButton(); }, errorHandler ); } else { var li = document.createElement("li"); var span = document.createElement("span"); span.innerText = "You chose not to delete the record. You can view the record "; var link = document.createElement("a"); link.href = SDK.REST._getServerUrl() + "/main.aspx?etc=1&id=%7b" + AccountId + "%7d&pagetype=entityrecord"; link.target = "_blank"; link.innerText = "here"; li.appendChild(span); li.appendChild(link); output.appendChild(li); enableResetButton(); } } |
