Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 18.07.2011, 01:48   #1
ideveloper is offline
ideveloper
How to overwrite a display value of the edit field
Hi all.
I have the following problem:
I have 2 data tables which represent the relation between the customers and the bonus codes.
Table A
BonusCode | recId
Table B
AccountNum | ArticleNum | TableARecId (as key)
Now I am trying to create a form containing the grid with the AccountNum, ArticleNum and the BonusCode. The BonusCode field should have a lookup function to the data in the Table A. When I get the value of the BonusCode with the display method I must create my own lookup method from zero to have the possibility to choose the data.
Could I instead include the TableARecId in the grid as the edit field and overwrite the show method to show the value of the bonus code???
edit field, lookup, overwrite display value
dynamicsaxtraining: How to access field in a table using this field id Blog bot DAX Blogs 0 09.12.2010 02:13
dynamicsaxtraining: How dynamically change data source field properties Blog bot DAX Blogs 0 06.12.2010 23:11
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
Зачем нужны display и edit методы Андре DAX: Программирование 4 15.08.2002 13:24
edit и display методы Maxim Gorbunov DAX: База знаний и проекты 4 15.01.2002 12:58
Часовой пояс GMT +3, время: 18:13.
