Старый 08.07.2011, 14:33   #22
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Сообщение от slivka_83 Посмотреть сообщение
я часто сталкивался с ситуациями когда из-за разности ролапов не накатывалась кастомизация. правда я точно не помню какие именно на них ролапы стояли
А почему именно второго?
Notes about how to export and to import customizations
You can export customizations from a server that is running Microsoft Dynamics CRM 4.0 with Update Rollup 2 or a later update rollup. Then, you can import those customizations to a server that has Update Rollup 18 installed. You can also export customizations from a server that is running Microsoft Dynamics CRM 4.0 with Update Rollup 18 installed. Then, you can import those customizations to a server that has Update Rollup 2 or a later update rollup installed.
If you export customizations from a server that is running Microsoft Dynamics CRM 4.0, you must not import the customizations to the Microsoft Dynamics CRM 4.0 server in the following scenarios:
  • The Microsoft Dynamics CRM 4.0 server that you use to export the customizations has no updates installed. Or, it has only Update Rollup 1 for Microsoft Dynamics CRM 4.0 installed. However, the server that you use to import the customizations has only Update Rollup 18 for Microsoft Dynamics CRM 4.0 installed.
  • The Microsoft Dynamics CRM 4.0 server that you use to export the customizations has only Update Rollup 18 for Microsoft Dynamics CRM 4.0 installed. However, the server that you use to import the customizations has no updates installed. Or, it has only Update Rollup 1 for Microsoft Dynamics CRM 4.0 installed.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Все о Microsoft Dynamics CRM: Как установить Microsoft Dynamics CRM 2011 Beta Blog bot Dynamics CRM: Blogs 0 31.10.2010 15:08
Microsoft Dynamics CRM Team Blog: Building Rich-Client Dashboards for Microsoft Dynamics CRM with Windows Presentation Foundation Blog bot Dynamics CRM: Blogs 1 31.03.2009 13:24
Часовой пояс GMT +3, время: 02:41.
