Старый 25.06.2011, 00:11   #1
Strange User Login Issue – Check User Settings
Источник: http://www.dynamicscare.com/blog/ind...user-settings/
If you’ve used CRM before and been part of the administrative group that sets up and modifies users, you are fully aware that a security role is required for a user to log into the CRM system. However, I have seen an issue where a user, with a security role, cannot log in. Be sure [...]
Microsoft Dynamics CRM Team Blog: Controlling User Synchronization Settings Blog bot Dynamics CRM: Blogs 0 02.06.2011 20:11
Dynamics AX Sustained Engineering: Issue with check numbers when exceeding the upper limit of a 32-bit integer Blog bot DAX Blogs 1 16.04.2011 10:10
Dianne Siebold: Find User Settings in the SysLastValue Table Blog bot DAX Blogs 0 09.01.2010 12:05
mscrm4ever: CRM 4.0 Logging user login information Blog bot Dynamics CRM: Blogs 0 14.07.2009 08:05
C# and AX Development: AX user cannot make login Blog bot DAX Blogs 1 26.07.2008 11:47
Часовой пояс GMT +3, время: 10:43.
