axaptapedia: StrRep
Источник: http://www.axaptapedia.com/StrRep
============== Summary: New page: ===Syntax=== str strrep(str text, int number) ===Description=== Return a string containing text repeated number times. ===Example=== strrep('ab', 3) //returns the text... ===Syntax=== str strrep(str text, int number) ===Description=== Return a string containing text repeated number times. ===Example=== strrep('ab', 3) //returns the text string 'ababab'. [[Category:String]] Источник: http://www.axaptapedia.com/StrRep
axaptapedia: StrLfix
Источник: http://www.axaptapedia.com/StrLfix
============== Summary: ===Syntax=== str strLfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char after string _str to obtain a string long _leng. Default filler chararcer is ' '. If _str is longer than _leght function return a substring of _str. ===Example=== strLfix('aaa', 5, '_') //returns the text string 'aaa__'. ==See also== * [[strRfix]] * [[strRep]] [[Category:String]] Источник: http://www.axaptapedia.com/StrLfix
axaptapedia: StrRfix
Источник: http://www.axaptapedia.com/StrRfix
============== Summary: New page: ===Syntax=== str strRfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char before string _str to obtain a string long _leng. Default filler chararc... ===Syntax=== str strRfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char before string _str to obtain a string long _leng. Default filler chararcer is ' '. If _str is longer than _leght function return a substring of _str. ===Example=== strRfix('aaa', 5, '_') //returns the text string '__aaa'. ==See also== * [[strLfix]] * [[strRep]] [[Category:String]] Источник: http://www.axaptapedia.com/StrRfix
axaptapedia: StrRep
Источник: http://axaptapedia.com/StrRep
============== Summary: New page: ===Syntax=== str strrep(str text, int number) ===Description=== Return a string containing text repeated number times. ===Example=== strrep('ab', 3) //returns the text... ===Syntax=== str strrep(str text, int number) ===Description=== Return a string containing text repeated number times. ===Example=== strrep('ab', 3) //returns the text string 'ababab'. [[Category:String]] Источник: http://axaptapedia.com/StrRep
Источник: http://axaptapedia.com/StrLfix
============== Summary: ===Syntax=== str strLfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char after string _str to obtain a string long _leng. Default filler chararcer is ' '. If _str is longer than _leght function return a substring of _str. ===Example=== strLfix('aaa', 5, '_') //returns the text string 'aaa__'. ==See also== * [[strRfix]] * [[strRep]] [[Category:String]] Источник: http://axaptapedia.com/StrLfix
Источник: http://axaptapedia.com/StrRfix
============== Summary: New page: ===Syntax=== str strRfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char before string _str to obtain a string long _leng. Default filler chararc... ===Syntax=== str strRfix(str _str, int _lenght [, char _char]) ===Description=== Add character _char before string _str to obtain a string long _leng. Default filler chararcer is ' '. If _str is longer than _leght function return a substring of _str. ===Example=== strRfix('aaa', 5, '_') //returns the text string '__aaa'. ==See also== * [[strLfix]] * [[strRep]] [[Category:String]] Источник: http://axaptapedia.com/StrRfix
