Старый 11.04.2011, 11:48   #3
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Вот нашел у себя в коде функцию:
Код:
var oTypeThis = crmForm.ObjectTypeCode;
var oTypeThisName = crmForm.ObjectTypeName;
var oTypeAssociated = Product;
var oTypeAssociatedName = "product";
var oAssociationName = "new_productsForLead";
var oAssociationRecordName = "new_productsforlead";
function getAssociatedRecordsIds()
    var oFetchXML =    "<fetch mapping='logical'>" +
                "<entity name='" + oAssociationRecordName + "'>" +
                    "<attribute name='" + oTypeAssociatedName + "id'/>" +
                    "<filter type='and'>" +
                        "<condition attribute='" + oTypeThisName + "id' operator='eq' value='" + crmForm.ObjectId + "'/>" +
                    "</filter>" +
                "</entity>" +
            "</fetch>";
        oFetchXML = oFetchXML.replace(/</g, '&lt;');
        oFetchXML = oFetchXML.replace(/>/g, '&gt;');
    var oSOAP =    "<?xml version='1.0' encoding='utf-8'?>"+
            "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'" +
                        " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'" +
                        " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>" +
                GenerateAuthenticationHeader() +
                "<soap:Body>" +
                    "<Fetch xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>" +
                        "<fetchXml>" +
                            oFetchXML +
                        "</fetchXml>" +
                    "</Fetch>"+
                "</soap:Body>"+
            "</soap:Envelope>";
    var oXmlHttp = new ActiveXObject("Msxml2.XMLHTTP");
    oXmlHttp.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
    oXmlHttp.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Fetch");
    oXmlHttp.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
    oXmlHttp.setRequestHeader("Content-Length", oSOAP.length);
    oXmlHttp.send(oSOAP);
    var oResponseText = oXmlHttp.responseXML.text;
    var oXmlDoc = new ActiveXObject("Microsoft.XMLDOM");
    oXmlDoc.async = false;
    oXmlDoc.loadXML(oResponseText);
    var results = oXmlDoc.getElementsByTagName(oTypeAssociatedName + "id");
    var associatedRecordsIds = new Array(results.length);
    for (var i = 0; i < results.length; i++)
        associatedRecordsIds[i] = results[i].text;
    return associatedRecordsIds;
Надеюсь это то что нужно. В принципе должно работать и с несистемными N:N отношениями, но возможно с рядом модификаций.
За это сообщение автора поблагодарили: Skyway (1).
javascript, soap, связь n:n
Помогите написать SOAP запрос kolya.master Dynamics CRM: Разработка 8 01.12.2009 16:47
SOAP и Join slivka_83 Dynamics CRM: Разработка 3 08.06.2009 10:13
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Фильтр для отчета - из списка связанных записей? AlekseyS Dynamics CRM: Разработка 3 11.09.2008 10:54
Добавление из списка существующих записей Boris Ilyin Dynamics CRM: Функционал 1 09.02.2007 08:34
Часовой пояс GMT +3, время: 16:42.
