Старый 09.08.2010, 10:18   #1
Krom is offline
Krom
Согласен думаю по коду будет проще понять в чем проблема:
Код:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Microsoft.Win32;
using SDK = Microsoft.Crm.Sdk;
using pluginUpdateKursperescheta.CrmSdk;
namespace pluginUpdateKursperescheta
    public class onUpdateKp : SDK::IPlugin
        public void Execute(SDK.IPluginExecutionContext context)
            CrmAuthenticationToken token = new CrmAuthenticationToken();
            token.AuthenticationType = 0;
            token.OrganizationName = context.OrganizationName;
            CrmService service = new CrmService();
            RegistryKey regkey = Registry.LocalMachine.OpenSubKey("SOFTWARE\\Microsoft\\MSCRM");
            service.Url = String.Concat(regkey.GetValue("ServerUrl").ToString(), "/2007/crmservice.asmx");
            service.CrmAuthenticationTokenValue = token;
            service.UseDefaultCredentials = true;
            SDK::DynamicEntity currentKp = context.PostEntityImages["KpIm"] as SDK::DynamicEntity;
            try
                if (currentKp.Properties.Contains("new_kursperesheta"))
                    ColumnSet cols = new ColumnSet()
                        Attributes = new string[] { "new_wholeamount" }
                    ConditionExpression cond = new ConditionExpression()
                        AttributeName = "quoteid",
                        Operator = ConditionOperator.Equal,
                        Values = new object[] { ((SDK::Key)currentKp.Properties["quoteid"]).Value }
                    FilterExpression filt = new FilterExpression()
                        Conditions = new ConditionExpression[] { cond }
                    QueryExpression query = new QueryExpression()
                        ColumnSet = cols,
                        EntityName = EntityName.quotedetail.ToString(),
                        Criteria = filt,
                    BusinessEntity[] buss = service.RetrieveMultiple(query).BusinessEntities;
                    decimal wholeamount = 0;
                    foreach (var item in buss)
                        wholeamount += ((quotedetail)item).new_wholeamount.Value;
                    ColumnSet colsTemp = new ColumnSet() { Attributes = new string[] { "new_temp_salesorderid" } };
                    ConditionExpression condTemp = new ConditionExpression()
                        AttributeName = "new_quoteid",
                        Values = new object[] {((SDK::Key)currentKp.Properties["quoteid"]).Value }
                    FilterExpression filTemp = new FilterExpression()
                        Conditions = new ConditionExpression[] { condTemp }
                    QueryExpression queryTemp = new QueryExpression()
                        ColumnSet = colsTemp,
                        EntityName = EntityName.new_temp_salesorder.ToString(),
                        Criteria = filTemp
                    BusinessEntity[] bussTemp = service.RetrieveMultiple(queryTemp).BusinessEntities;
                    if (bussTemp.Length > 0)
                        new_temp_salesorder tempSales = new new_temp_salesorder();
                        tempSales.new_temp_salesorderid = new Key() { Value = ((new_temp_salesorder)bussTemp[0]).new_temp_salesorderid.Value };
                        tempSales.new_quoteid = ((SDK::Key)currentKp.Properties["quoteid"]).Value.ToString();
                        tempSales.new_totallineitemamount = new CrmMoney() { Value = wholeamount };
                        tempSales.new_discountamount = new CrmMoney() { Value = wholeamount - (wholeamount * ((SDK::CrmDecimal)currentKp.Properties["discountpercentage"]).Value / 100) };
                        tempSales.new_totaltax = new CrmMoney() { Value = tempSales.new_discountamount.Value * Convert.ToDecimal(0.18) };
                        tempSales.new_totalamount = new CrmMoney() { Value = tempSales.new_totaltax.Value + tempSales.new_discountamount.Value };
                        service.Update((BusinessEntity)tempSales);
                    else
                        tempSales.new_temp_salesorderid = new Key();
                        tempSales.new_name = ((SDK::Key)currentKp.Properties["quoteid"]).Value.ToString();
                        tempSales.ownerid = new Owner() { Value = ((SDK::Lookup)currentKp.Properties["createdby"]).Value };
// тут падает service.Create((BusinessEntity)tempSales)	Cannot call 'pluginUpdateKursperescheta.CrmSdk.CrmService.Create(pluginUpdateKursperescheta.CrmSdk.BusinessEntity)' because it is a web method.
                        service.Create((BusinessEntity)tempSales);
            catch (System.Web.Services.Protocols.SoapException ex)
                throw new SDK::InvalidPluginExecutionException(
                   String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex);
Последний раз редактировалось Krom; 09.08.2010 в 10:58.
Старый 09.08.2010, 14:45   #2
Гуревич Денис is offline
Гуревич Денис
228 / 67 (3) ++++
Код:
А зачем Вы к BusinessEntity приведение делаете? Это лишне.
Опыт позволяет ошибаться гораздо увереннее.
Старый 09.08.2010, 15:19   #3
Krom is offline
Krom
Проблему, к сожалению, это не решает.
Возможно и лишнее
Старый 09.08.2010, 16:55   #4
ZooY is offline
ZooY
Аватар для ZooY
379 / 46 (2) +++
Не очень понятно, а накой вы в плагине таким вот способом создаете экземпляр сервиса, почему не делаете так:
ICrmService service = context.CreateCrmService(true);
Может проблема как раз в этом?
И как регистрируете плагин, на какой событие, какой сущности и что в плане синхронности?
Старый 09.08.2010, 18:26   #5
Гуревич Денис
228 / 67 (3) ++++
Да тут вообще жуткая каша из неймспейсов.
Надо было пользоваться либо только классами веб-сервиса, либо (что правильнее) только Microsoft.Crm.Sdk. А как сейчас это компилится, я даже не представляю.
Старый 10.08.2010, 15:19   #6
Krom is offline
Krom
Ошибка была тут:
Понял, что если выдает ошибку такого типа, значит какой-то атрибут не нравится.
По поводу неймспейсов: их всего 2. Web Service тянет кастомные сущности.
Честно говоря по-другому я не умею. Когда-то показали такую схему, так и работаю
Если покажите аналогичный функционал, используя только Microsoft.Crm.Sdk буду очень благодарен
Старый 10.08.2010, 15:34   #7
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Сообщение от Krom Посмотреть сообщение
Ошибка была тут:
DynamicEntity предоставляют возможность не использовать WebReference. Рекомендую.
Доступ к данным из IFD CRM ZooY Dynamics CRM: Разработка 20 31.03.2010 11:18
Microsoft Dynamics CRM Team Blog: CRM Online: ‘Contact Us’ Web Form Made Easy Blog bot Dynamics CRM: Blogs 0 20.05.2009 05:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Microsoft Dynamics CRM Team Blog: Announcing List Web Part for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 18.12.2008 06:06
Часовой пояс GMT +3, время: 21:57.
