Старый 19.07.2010, 11:05   #3
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Actually, you'll see a lot more of those in the new AX release.
There is nothing wrong with putting such statements into the code.
Their purpose is to assert a very specific condition, that MUST be satisfied.
If it is not, something is VERY wrong, and we should not continue.
They are intended for developers changing the code - when doing some testing of the changes, you would be able to easily see that something is wrong.
So, again - this is a good thing that they are there.
jinx: Dynamics AX 2009 - Ungewollt den Sys Layer ändern Blog bot DAX auf Deutsch 1 12.03.2009 11:32
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 09:00.
