Старый 07.07.2010, 02:06   #7
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Записей в блоге: 1
Ничего недокументированного или шаманского нет.
Что за шаманский контейнер передается в качестве аргумента и что за три параметра в этом контейнере?
breakpoint
(xinfo) public final container breakpoint([container _breakpoint])
this method will be used to get a list of all breakpoints and/or for set a list of breakpoints
_breakpoint
optional input container for setting the breakpoints
return
- container-content
the first element contains a '1' (version-number of the container-structure)
for each breakpoint 3 additional elements
- string:the treenode-path of the method containing the breakpoint
- integer:the row-number of the breakpoint
- boolean:is the breakpoint active ?
Example 1
take a look at the form SysBreakPoints [Shift F9]
Example 2
use the editor to set some breakpoints (doesn't matter where)
http://www.axaptapedia.com/Infolog_class#breakpoint
kamalblogs: Adding custom images for Treenode in Dynamics Ax Blog bot DAX Blogs 0 25.01.2010 17:05
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 18:53.
