kamalblogs: Grouping orders in Master planning
Источник: http://kamalblogs.wordpress.com/2010...ster-planning/
============== In the Dimension group setup there is on options “Coverage plan by dimension” This dimension setup decides how issues are grouped based on dimensions But just this setup wouldn’t be enough to achieve grouping when you run the scheduling engine. Make sure you also setup the “Coverage code” in the Item Coverage group to “Period”. If this setup is not done then you will still find issues getting created individually or based on Min Max Once you have both in place, then the grouping starts working based on the “coverage plan by dimension” setup. ![]() Источник: http://kamalblogs.wordpress.com/2010...ster-planning/
