Старый 19.01.2010, 14:34   #1
Rage is offline
Rage
Это exec sp_who2 active
SPID Status Login HostName BlkBy DBName Command CPUTime DiskIO LastBatch ProgramName SPID REQUESTID
150 SUSPENDED bmssa AXAOS 212 axdb SELECT 9602 194 01/19 13:25:33 Navision Axapta 150 0
163 SUSPENDED bmssa AXAOS 212 axdb SELECT 20720 250 01/19 13:24:56 Navision Axapta 163 0
178 SUSPENDED bmssa AXAOS 212 axdb SELECT 1042 220 01/19 13:26:06 Navision Axapta 178 0
186 SUSPENDED bmssa AXAOS 212 axdb SELECT 13496 493 01/19 13:25:48 Navision Axapta 186 0
191 SUSPENDED bmssa AXAOS 212 axdb SELECT 1187 124 01/19 13:29:01 Navision Axapta 191 0
202 SUSPENDED bmssa AXAOS 212 axdb SELECT 0 2 01/19 13:27:38 Navision Axapta 202 0
205 RUNNABLE bmssa AXAOS axdb SELECT 50106 974 01/19 13:29:34 Navision Axapta 205 0
207 SUSPENDED bmssa AXAOS 212 axdb SELECT 811 130 01/19 13:28:29 Navision Axapta 207 0
212 SUSPENDED bmssa AXAOS 138 axdb SELECT 8650 352 01/19 13:29:08 Navision Axapta 212 0
215 SUSPENDED bmssa AXAOS 202 axdb SELECT 0 1 01/19 13:28:50 Navision Axapta 215 0
Старый 19.01.2010, 14:36   #2
Rage is offline
Rage
Это sp_lock
spid dbid ObjId IndId Type Resource Mode Status
58 20 1068595641 1 PAG 1:2707701 IU GRANT
58 20 1068595641 1 PAG 1:2707700 IU GRANT
58 20 1068595641 1 PAG 1:2707703 IU GRANT
58 20 1068595641 1 PAG 1:2707702 IU GRANT
58 20 1068595641 1 PAG 1:2707697 IU GRANT
58 20 1068595641 1 PAG 1:2707696 IU GRANT
58 20 1068595641 1 PAG 1:2707699 IU GRANT
58 20 1068595641 1 PAG 1:2707698 IU GRANT
58 20 1068595641 1 PAG 1:2707653 IU GRANT
58 20 1068595641 1 PAG 1:2707652 IU GRANT
58 20 1068595641 1 PAG 1:2707655 IU GRANT
58 20 1068595641 1 PAG 1:2707654 IU GRANT
58 20 1068595641 1 PAG 1:2707649 IU GRANT
58 20 1068595641 1 PAG 1:2707648 IU GRANT
58 20 1068595641 1 PAG 1:2707651 IU GRANT
58 20 1068595641 1 PAG 1:2707650 IU GRANT
58 20 1068595641 1 PAG 1:2707597 IU GRANT
58 20 1068595641 1 PAG 1:2707596 IU GRANT
58 20 1068595641 1 PAG 1:2707599 IU GRANT
151 20 471526 4 KEY (bf025b1b5b3f) X GRANT
151 20 811643922 2 KEY (7901adccc22e) X GRANT
151 20 830403965 4 KEY (ff03121465d4) X GRANT
151 20 811643922 3 KEY (030392cf1499) X GRANT
151 20 1085845018 15 PAG 1:921055 IX GRANT
151 20 1085845018 7 PAG 1:890479 IX GRANT
151 20 1085845018 14 KEY (e5017a3ff9fa) X GRANT
151 20 830403965 3 KEY (23031b2c635e) X GRANT
151 20 1085845018 15 KEY (720427f8e234) X GRANT
151 20 811643922 0 RID 1:10782259:9 X GRANT
151 20 1085845018 14 PAG 1:912192 IX GRANT
151 20 830403965 4 PAG 1:61747 IX GRANT
151 20 811643922 0 TAB IX GRANT
151 20 1088448839 1 KEY (bd034a2011fc) U GRANT
151 20 1085845018 8 KEY (e101a137b83a) X GRANT
151 20 830403965 5 KEY (060242cf2fe9) X GRANT
151 20 1085845018 8 PAG 1:10787568 IX GRANT
151 20 830403965 0 RID 1:10756673:19 X GRANT
151 20 1085845018 0 PAG 1:10781871 IX GRANT
151 20 1085845018 0 PAG 1:10781869 IX GRANT
151 20 1085845018 0 RID 1:10781869:3 X GRANT
151 20 1085845018 6 KEY (e901fce593ff) X GRANT
151 20 1085845018 4 PAG 1:884348 IX GRANT
151 20 811643922 0 PAG 1:10782259 IX GRANT
151 20 811643922 0 RID 1:10782259:5 X GRANT
И таких записей ооочень много!
20 - это ID промышленной базы.
Старый 19.01.2010, 14:40   #3
Rage is offline
Rage
Это блокировки из администрирования АХ
Объект базы данных Процесс идентификации Статус блокировки Тип блокировки Режим блокировки Статус блокировки Время ожидания Пользователь
INVENTITEMLOCATION 212 Блокировка Блокировка ключа индексации Блокировка обновления Разрешение 0 <Не определено>
INVENTITEMLOCATION 212 Блокировка Блокировка ключа индексации Исключающая блокировка Разрешение 0 <Не определено>
INVENTJOURNALTABLE 162 Блокировка Блокировка ключа индексации Блокировка обновления Разрешение 0 <Не определено>
INVENTTRANSPOSTING 138 Блокировка Блокировка ключа индексации Исключающая блокировка Разрешение 0 <Не определено>
OFFICIALSTRANS_RU 151 Блокировка Блокировка страницы Нет Разрешение 0 <Не определено>
OFFICIALSTRANS_RU 71 Ожидание Блокировка страницы Блокировка обновления Ожидание 92385 <Не определено>
Старый 19.01.2010, 15:10   #4
Andrey Peganov is offline
Andrey Peganov
Стандартно в INVENTITEMLOCATION по одной записи на каждую номенклатуру, т.е. нет разреза по аналитикам. При разноске эта запись блокируется, что не позволяет параллельно разносить документы с той же номенклатурой, но с другими аналитиками.
Можно генерить записи для каждой номенклатуры по всем значениям определенных аналитик. Тогда журналы по одной номенклатуре, но по разным складам, разным партиям будут разноситься параллельно.
С OFFICIALSTRANS_RU посмотрите метод new() класса OfficialsServ_RU. Он при каждом создании класса он пытается удалить строки, что вызывает жесткие блокировки. Решение по меньшей мере странное. Можно закоментить вызов this.cleanUp(), и это никаких траблов не создаст, но блокировок не будет.
Поставьте в параметрах всех пользователей Аксапты трассировку длинных запросов (> 10000 мс). Это поможет определить место кода, в котором блокируются данные
За это сообщение автора поблагодарили: Antonuch (1), Kabardian (2).
Старый 19.01.2010, 16:15   #5
Rage is offline
Rage
После модификаций программистами (отключение индекс хинтов, исправление методов в классе OfficialsServ_RU), остались блокировки по этим таблицам, ну и соответственно веселье продолжается
INVENTITEMLOCATION 150 Блокировка Блокировка ключа индексации Блокировка обновления Разрешение 0 <Не определено>
SPECTRANS 55 Блокировка Блокировка ключа индексации Исключающая блокировка Разрешение 0 <Не определено>
блокировки таблицы WMTRANSFER_FACTUREJOUR. ipas DAX: Администрирование 0 29.09.2008 15:20
Мертвые блокировки при резерве Logger DAX: Программирование 36 19.11.2007 16:29
По каким счетам формируются проводки в ГК при обработке накладной? matew DAX: Программирование 1 12.10.2007 13:30
По каким счетам формируются проводки в ГК при обработке накладной? matew DAX: Функционал 5 11.10.2007 17:50
Ошибка при обработке входящего НДС RAM DAX: Функционал 14 08.09.2004 18:24
Часовой пояс GMT +3, время: 13:54.
