Старый 06.11.2009, 03:49   #3
Timofey_k is offline
Timofey_k
Microsoft Dynamics
Аватар для Timofey_k
20 / 50 (2) ++++
На query, на базе которого построен сервис, в датасорсах включи Update = Yes.
If you want to use a Dynamics AX document service to write data back to the database - that is, if you need to support the service operation update - you need to set the AOT property Update to Yes for all data sources the query used to generate the service.
Последний раз редактировалось Timofey_k; 06.11.2009 в 03:55.
aif
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
emeadaxsupport: Problems when trying to update a certain field with AIF Blog bot DAX Blogs 0 19.08.2009 18:05
Dianne Siebold: Rec Fields Required in AIF Partial Update Blog bot DAX Blogs 0 20.01.2009 09:05
gatesasbait: Table caching and record delete()/update()/next Blog bot DAX Blogs 3 24.04.2008 22:55
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 17:10.
