Старый 04.09.2009, 14:39   #3
xmarina is offline
xmarina
Ошибка - см. вложение
В журнале событий:
Event Type: Error
Event Source: MSCRMReporting
Event Category: None
Event ID: 19969
Date: 9/4/2009
Time: 2:21:42 PM
User: N/A
Computer: CRM_APP
Description:
Web service request SetDataSourceCredentials to Report Server http://crm_db/ReportServer failed with SoapException. Error: Произошла ошибка при обработке отчета. (rsProcessingAborted)
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Warning
Event Source: ASP.NET 2.0.50727.0
Event Category: Web Event
Event ID: 1309
Date: 9/4/2009
Time: 2:21:42 PM
User: N/A
Computer: CRM_APP
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 9/4/2009 2:21:42 PM
Event time (UTC): 9/4/2009 10:21:42 AM
Event ID: fc0dd3164cd84eaeb60ecef878c93f0d
Event sequence: 3549
Event occurrence: 17
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-128965111722411830
Trust level: Full
Application Virtual Path: /
Application Path: D:\Microsoft Dynamics CRM\CRMWeb\
Machine name: CRM_APP
Process information:
Process ID: 284
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
Exception type: CrmReportingException
Exception message: Произошла ошибка при обработке отчета. (rsProcessingAborted)
Request information:
Request URL: http://crm_app:5555/ORG/CRMReports/r...ortviewer.aspx
Request path: /ORG/CRMReports/rsviewer/reportviewer.aspx
User host address: 10.3.1.7
User: ENG\xmarina1
Is authenticated: True
Authentication Type: Negotiate
Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
Thread ID: 1
Is impersonating: False
Stack trace: at Microsoft.Crm.Web.Reporting.SrsReportViewer.SetExecutionCredentials(ServerReport report)
at Microsoft.Crm.Web.Reporting.SrsReportViewer.ConfigurePage()
at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e)
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
В логе IIS:
2009-09-04 10:28:46 W3SVC1 10.1.1.197 GET /ORG/_grid/preview.aspx type=9100&id={550F1E7A-54FF-DD11-A556-0015609D4CA1} 5555 - 10.3.1.7 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.1;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.648;+.NET+CLR+3.5.21022;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729;+InfoPath.1) 401 2 2148074254
2009-09-04 10:28:46 W3SVC1 10.1.1.197 GET /ORG/_grid/preview.aspx type=9100&id={550F1E7A-54FF-DD11-A556-0015609D4CA1} 5555 ENG\xmarina1 10.3.1.7 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.1;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.648;+.NET+CLR+3.5.21022;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729;+InfoPath.1) 200 0 0
2009-09-04 10:28:47 W3SVC1 10.1.1.197 GET /ORG/crmreports/viewer/viewer.aspx id={550F1E7A-54FF-DD11-A556-0015609D4CA1}&helpID=Activities.rdl&action=filter 5555 - 10.3.1.7 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.1;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.648;+.NET+CLR+3.5.21022;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729;+InfoPath.1) 401 2 2148074254
2009-09-04 10:28:47 W3SVC1 10.1.1.197 GET /ORG/crmreports/viewer/viewer.aspx id={550F1E7A-54FF-DD11-A556-0015609D4CA1}&helpID=Activities.rdl&action=filter 5555 DEVEL\xmarina1 10.3.1.7 Mozilla/4.0+(compatible;+MSIE+7.0;+Windows+NT+5.1;+.NET+CLR+1.1.4322;+.NET+CLR+2.0.50727;+.NET+CLR+3.0.04506.648;+.NET+CLR+3.5.21022;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729;+InfoPath.1) 200 0 0
Где еще смотреть - не знаю.
В самом начале при возникновении ошибки была ситуация, похожая на http://axforum.info:80/forums/showthread.php?p=171944,
но повторный запуск отчетов не помог.
Пробовала создать свой тестовый отчет через Visual Studio и настроила у него свой DataSource. Везде работает, на сервере CRM - запускается, но данные не возваращает (вижу только шапку). Прочитала в документации, что это может быть, если нет прав доступа к данным.
Поскольку за авторизацию отвечает коннектор, есть подозрение, что с ним что-то не так.
Изображения
Microsoft Dynamics CRM Team Blog: CRM Online: Reporting Options Blog bot Dynamics CRM: Blogs 0 18.06.2009 06:14
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 4.0 Bookshelf Blog bot Dynamics CRM: Blogs 1 22.01.2009 04:46
Microsoft Dynamics CRM Team Blog: How it Works: SQL Server Reporting Services and Dynamics CRM Blog bot Dynamics CRM: Blogs 0 19.07.2008 04:42
Часовой пояс GMT +3, время: 14:03.
