Старый 04.08.2009, 19:12   #7
alsherin is offline
alsherin
Трассировка включена с помощью Microsoft Crm Diagnostics Tool 4, но в логе нет сообщения об ошибке. Пишет 2 лога: CRMWeb и CRMAsyncService. Ниже фаргмент веб-лога, в котором вызывается страница показа ошибки:
Код:
>MapOrgEngine: Retreived the OrgId[{03215DE1-08B9-43F6-AC53-4FBF9E524C9A}] for URL[http://mycompany-sbs:5555/mycompany-CRM/_forms/FormScript.js.aspx?etc=8&FormType=main&FormName=crmForm].
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute
	at SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
	at HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
	at ApplicationStepManager.ResumeSteps(Exception error)
	at HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData)
	at HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr)
	at HttpRuntime.ProcessRequestNoDemand(HttpWorkerRequest wr)
	at ISAPIRuntime.ProcessRequest(IntPtr ecb, Int32 iWRType)
>AUTH: Request [GET http://mycompany-sbs:5555/mycompany-CRM/_forms/FormScript.js.aspx?etc=8&FormType=main&FormName=crmForm] entered Authentication Pipeline.
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | AuthenticationPipeline.Authenticate
	at AuthenticationPipeline.Authenticate(HttpApplication application)
	at AuthenticationEngine.Execute(Object sender, EventArgs e)
>AUTH: AuthenticationProvider [Microsoft.Crm.Authentication.WindowsAuthenticationProvider] will be atempted.
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | WindowAuthenticationProviderBase.Authenticate
	at WindowAuthenticationProviderBase.Authenticate(HttpApplication application)
	at AuthenticationStep.Authenticate(HttpApplication application)
>WindowsAuthenticationProvider published CrmWindowsIdentity [UserToken:W:S-1-5-21-3643464063-1753334398-1307092419-1142] [UserId:{1A59AD16-5757-DE11-9AD7-0018F396FD43}].
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Info | AuthenticationPipeline.Authenticate
>AUTH: AuthenticationProvider [Microsoft.Crm.Authentication.WindowsAuthenticationProvider] handled request [http://mycompany-sbs:5555/mycompany-CRM/_forms/FormScript.js.aspx?etc=8&FormType=main&FormName=crmForm].
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | BuildResult.ComputeSourceDependenciesHashCode
	at BuildResult.ComputeSourceDependenciesHashCode(VirtualPath virtualPath)
	at BuildResult.IsUpToDate(VirtualPath virtualPath)
	at MemoryBuildResultCache.GetBuildResult(String cacheKey, VirtualPath virtualPath, Int64 hashCode)
	at BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode)
	at BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
	at BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
	at BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
	at BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
	at PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
	at HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)
	at MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
>GetFileHash(/mycompany-CRM/_forms/FormScript.js.aspx, System.Collections.ArrayList) called.
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform.Sql |User: 00000000-0000-0000-0000-000000000000 |Level: Info | CrmDbConnection.ExecuteNonQuery
	at CrmDbConnection.ExecuteNonQuery(IDbCommand command, Boolean impersonate)
	at CrmDbConnection.SetTransactionIsolationLevel(IsolationLevel il)
	at CrmDbConnection.Open()
	at DatabaseService.Retrieve(String tableName, String[] columns, PropertyBag[] conditions)
	at DatabaseService.RetrieveById(String tableName, Object id, String[] columns)
	at ServerLocatorService.RetrieveById(String tableName, Object primaryKey, String[] columns)
	at ServerLocatorService.GetOrganization(Guid organizationId)
	at ApplicationConfig.Retrieve(String propertyName, Object defaultValue, Guid organizationId)
	at ApplicationConfig.IIsAllowCaching(Guid organizationId)
	at MainApplication.Application_OnPostRequestHandlerExecute(Object sender, EventArgs eventArguments)
>SET TRANSACTION ISOLATION LEVEL READ COMMITTED
[2009-08-04 17:27:34.0] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform.Sql |User: 00000000-0000-0000-0000-000000000000 |Level: Info | CrmDbConnection.ExecuteReader
	at CrmDbConnection.ExecuteReader(IDbCommand command, Boolean impersonate)
	at DatabaseService.ExecuteBaseReader(CrmDbConnection connection, IDbCommand command, String[] columns)
>SELECT Id, ConnectionString, DatabaseName, FriendlyName, HelpContentServerUrl, MirroredSqlServerName, PartitionNumber, ScaleGroupId, SqlServerName, SrsUrl, State, SupportUserCrmUserId, Type, UniqueName FROM Organization  WHERE (((Id = '03215de1-08b9-43f6-ac53-4fbf9e524c9a')) ) AND (IsDeleted = 0)
	at DatabaseService.ExecutePropertiesReader(CrmDbConnection connection, IDbCommand command, String[] columns, PropertyBagCollection resultSet)
>SELECT Id, ColumnName, BigIntColumn, IntColumn, SmallIntColumn, TinyIntColumn, BitColumn, FloatColumn, DateTimeColumn, SmallDateTimeColumn, NVarCharColumn, UniqueIdentifierColumn, VarBinaryColumn FROM OrganizationProperties WHERE Id IN (SELECT Id FROM Organization WHERE (((Id = '03215de1-08b9-43f6-ac53-4fbf9e524c9a')) ) AND (IsDeleted = 0))
[2009-08-04 17:27:34.2] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute
>MapOrgEngine: Retreived the OrgId[{03215DE1-08B9-43F6-AC53-4FBF9E524C9A}] for URL[http://mycompany-sbs:5555/mycompany-CRM/_common/error/dlg_error.aspx?hresult=&errMessage=].
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute
>AUTH: Request [GET http://mycompany-sbs:5555/mycompany-CRM/_common/error/dlg_error.aspx?hresult=&errMessage=] entered Authentication Pipeline.
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | AuthenticationPipeline.Authenticate
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | WindowAuthenticationProviderBase.Authenticate
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Info | AuthenticationPipeline.Authenticate
>AUTH: AuthenticationProvider [Microsoft.Crm.Authentication.WindowsAuthenticationProvider] handled request [http://mycompany-sbs:5555/mycompany-CRM/_common/error/dlg_error.aspx?hresult=&errMessage=].
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Verbose | BuildResult.ComputeSourceDependenciesHashCode
>GetFileHash(/mycompany-CRM/_common/error/dlg_error.aspx, System.Collections.ArrayList) called.
[2009-08-04 17:27:34.5] Process: w3wp |Organization:03215de1-08b9-43f6-ac53-4fbf9e524c9a |Thread:    3 |Category: Application |User: 00000000-0000-0000-0000-000000000000 |Level: Info | Util.TraceMessage
	at Util.TraceMessage(TraceLevel level, String message, Object[] args)
	at AppForm.ConfigureControl()
	at CrmUIControlBase.ConfigureControlInternal()
	at Control.PreRenderRecursiveInternal()
	at Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
	at Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
	at Page.ProcessRequest()
	at Page.ProcessRequest(HttpContext context)
	at mycompany_crm__common_error_dlg_error_aspx.ProcessRequest(HttpContext context)
	at CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
>UserId ({1A59AD16-5757-DE11-9AD7-0018F396FD43}): AppForm.ConfigureControl: QueryString : /mycompany-CRM/_common/error/dlg_error.aspx?hresult=&errMessage=
[2009-08-04 17:27:34.5] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread:    3 |Category: Platform.Sql |User: 00000000-0000-0000-0000-000000000000 |Level: Info | CrmDbConnection.ExecuteNonQuery
	at ApplicationConfig.HelpContentServerUrl(Guid organizationId)
	at AppHeader.AddGlobalValues()
	at Header.PrepareHeader()
	at Header.Render(HtmlTextWriter output)
	at Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
	at Page.Render(HtmlTextWriter writer)
Описания ошибки к сожалению нет никакого - атрибут пустой.
ошибка 500 при создании и авторизации пользователя из домена Dr.Melkiades Dynamics CRM: Администрирование 5 16.06.2009 08:22
Ошибка после изменениями имени пользователя в AD sergeyjb Dynamics CRM: Администрирование 20 29.10.2008 18:27
Ошибка определения пользователя в CRM Gangztta Dynamics CRM: Функционал 29 08.10.2008 11:15
Ошибка создания связаной записи Talisman2005 Dynamics CRM: Администрирование 1 07.07.2008 21:15
Создание пользователя через SDK Tigra Dynamics CRM: Разработка 1 18.10.2005 18:27
Часовой пояс GMT +3, время: 12:42.
