Старый 03.06.2009, 13:01   #10
Murzin Andrey is offline
Murzin Andrey
Спасибо, разобрался. Заработало.
Только теперь другая проблема. При выборе бизнес-партнера появляются сообщения со значениями искомых полей. Как их убрать? ))
Код такой:
var lookupItem = new Array;
lookupItem = crmForm.all.customerid.DataValue;
var accountid = "lookupItem[0].id";
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>account</entityName>"+
"<id>"+lookupItem[0].id+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>telephone1</q1:Attribute>"+
"</q1:Attributes>"+
"<q1:Attributes>"+
"<q1:Attribute>name</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Display the retrieved value.
else
alert(resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue);
alert(resultXml.selectSingleNode("//q1:name").nodeTypedValue);
crmForm.all.telephone1.DataValue = resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue;
crmForm.all.companyname.DataValue = resultXml.selectSingleNode("//q1:name").nodeTypedValue;
Где найти веб-форму Преобразования интереса? Impulse Dynamics CRM: Разработка 2 28.09.2008 13:55
Ошибка при создании веб-ссылки в MS VS? Alexey-IT Dynamics CRM: Разработка 1 12.01.2008 03:24
Через веб не отображается полученная почта Hungrymar Dynamics CRM: Администрирование 14 19.12.2006 10:09
Не могу отправить почту через веб-интерфейс Hungrymar Dynamics CRM: Администрирование 0 18.11.2006 09:44
Ошибки в веб интерфесе DiMish Dynamics CRM: Администрирование 5 29.11.2005 17:50
Часовой пояс GMT +3, время: 20:40.
