Вернуться   AXForum > Прочие обсуждения > Обсуждение форума
Старый 28.04.2009, 17:01   #10
Aleksey_M is offline
Aleksey_M
Аватар для Aleksey_M
520 / 355 (13) ++++++
kashperuk
Ну вот примерно так. Тупо в лоб. Со всеми некрасивостями.
PHP код:
        // remove htmlspecialchars'd bits and excess spacing
$code rtrim($code);
$code preg_replace('#^\W*\n#'''$code); //Вырезаем ведущие переводы строки
$operators = array('abstract''anytype''asc''at''avg''break''breakpoint''by''byref''case''catch''changecompany''class''classnum''classstr''client''configurationkeynum''configurationkeystr''container''continue''count''crosscompany''date''default''delete_from''desc''display''div''do''edit''else''enumnum''enumstr''exists''extendedtypenum''extendedtypestr''extends''false''featurekeynum''featurekeystr''fieldnum''fieldpname''fieldstr''final''firstfast''firstonly''firstonly10''firstonly100''firstonly1000''flush''for''forceliterals''forcenestedloop''forceplaceholders''forceselectorder''formstr''forupdate''from''group''helpapplstr''helpdevstr''hint''htmlpdahorizontalpagestr''htmlpdaverticalpagestr''htmlstandardpagestr''identifierstr''if''implements''index''indexnum''indexstr''insert_recordset''int''int64''interface''join''left''licensecodenum''licensecodestr''like''literalstr''maxof''menuitemactionstr''menuitemdisplaystr''menuitemoutputstr''menustr''methodstr''minof''mod''nbofetch''new''next''nofetch''not''notexists''null''optimisticlock''order''outer''pause''pessimisticlock''print''private''protected''public''querystr''real''repeatableread''resourcestr''retry''return''reverse''right''securitykeynum''securitykeystr''select''server''setting''static''staticmethodstr''str''sum''super''switch''tablecollectionstr''tablefieldgroupstr''tablelock''tablemethodstr''tablenum''tablepname''tablestaticmethodstr''tablestr''throw''true''try''ttsabort''ttsbegin''ttscommit''typeid''update_recordset''varstr''void''webclientfilestr''webformstr''webmenustr''webreportstr''webserverfilestr''where''while''window');
$string_1 false// '
$string_2 false// "
$comment 0;    // 1 - было /
                // 2 - было //
                // 3 - было /*
$slash false// было \
$word '';
$result '';
        for (
$i 0$i strlen($code); $i++)
$char $code{$i};
//сбрасываем признак начала возможного комментария
if ($comment == && $char != '/' && $char != '*')
$comment 0;
$word .= '/';
            switch (
$char) {
            case
                if (
$comment<&& !$string_2 && !$slash)
                    if (
$string_1)
$result .= '<span style="color: red">'.htmlspecialchars($word.$char).'</span>';
$string_1 false;
$string_2 false;
$comment 0;
$word '';
                    }else{
$result .= htmlspecialchars($word);
$word $char;
$string_1 true;
                }else{
$word .= "'";
$slash false;
                break;
            case
                if (
$comment<&& !$string_1 && !$slash)
                    if (
$string_2)
$string_1 false;
$string_2 false;
$comment 0;
$word '';
                    }else{
$word $char;
$string_2 true;
                }else{
$word .= '"';
$slash false;
                break;
            case
                switch (
$comment) {
                case
0:
                    if (!
$string_1 && !$string_2)
//$word .= $char; добавим после
$comment 1;
                    }else{
$word .= $char;
                    break;
                case
1:
$word $char;
$string_1 false;
$string_2 false;
$comment 2;
                    break;
                case
2:
$word .= $char;
                    break;
                case
3:
                    if (
$comment == && $code{($i==0)?1:$i-1}=='*')
$result .= '<span style="color: green">/'.htmlspecialchars($word.$char).'</span>';
$string_1 false;
$string_2 false;
$comment 0;
$word '';
                    }else{
$word .= $char;
$slash false;
                break;
            case
$slash = !$slash;
$word .= $char;
                break;
            case
"\n":
                if (
$comment == 2)
$string_1 false;
$string_2 false;
$comment 0;
$word '';
                }else{
$word .= $char;
$slash false;
                break;
            case
                if (
$comment == 1)
$word $char;
$string_1 false;
$string_2 false;
$comment 3;
                }else{
$word .= $char;
$slash false;
                break;
            default:
                if (!
$string_1 && !$string_2 && $comment<2)
                    if (
in_array(strtolower($char),array('0','1','2','3','4','5','6','7','8','9',
'a','b','c','d','e','f','g','h','i','j','k','l','m','n','o','p','q','r','s','t','u','v','w','x','y','z')))
$word .= $char;
                    }elseif (
in_array(strtolower($word), $operators))
$result .= '<span style="color: blue">'.htmlspecialchars($word).'</span>'.$char;
$word '';
                    }else{
$result .= htmlspecialchars($word.$char);
$word '';
                }else{
$word .= $char;
$slash false;
//Подсвечиваем незакрытое
if ($string_1 OR $string_2)
$result .= '<span style="color: red">'.htmlspecialchars($word).'</span>';
$string_1 false;
$string_2 false;
$comment 0;
$word '';
        elseif (
$comment 1)
$result .= '<span style="color: green">/'.htmlspecialchars($word).'</span>';
$string_1 false;
$string_2 false;
$comment 0;
$word '';
$code $result htmlspecialchars($word);
Был грязный плащ на нем одет,
Цилиндр черный смят в гармошку...
За это сообщение автора поблагодарили: kashperuk (5).
x++, подсветка
Часовой пояс GMT +3, время: 00:39.
