Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 27.03.2009, 13:50   #6
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от em# Посмотреть сообщение
The table we want to allow permissions - tmpInventTransWMS - has a Security key on SYS layer. So, what security setup needs to be done for a particular user group to avoid this error? If temp tables have Security keys on SYS layer it is possible that there’s a way to manage them?
You can modify the table and clear its SecurityKey property. Or as you've mentioned you can enable access to the corresponding SecurityKey and disable access to other affected "persistent" tables on a per-table basis.
We can enable access to the temp table by setting access for the Security key the table is attached (in particularly for InventTables key), but it will enable some extra permissions to the user group.
Build CrossReferencies and look where a particular security key is used. As to the InventTables key, it seems that the only extra permission it gives (that cannot be disabled) is access to some other temporary tables from Invent and WMS modules. Also note that if a table has a ConfigKey attached and that ConfigKey is disabled then the table also becomes temporary despite its Temporary property value.
PS. Here's a sample job to find other temporary tables with SecurityKey set
Dictionary      dict = new Dictionary();
DictTable       dictTbl;
Counter         n;
for (n = 1; n <= dict.tableCnt(); n++)
    dictTbl = new DictTable( dict.tableCnt2Id( n ) );
    if (dictTbl && dictTbl.isTmp() && dictTbl.securityKeyId())
        if (dictTbl.configurationKeyId() && !isConfigurationKeyEnabled( dictTbl.configurationKeyId() ))
            continue;                       // table is temporarty 'coz the corresponding configKey is disabled
        info( strfmt( @"Temporary table %1 has securityKey: %2", dictTbl.name(), securitykeyid2name( dictTbl.securityKeyId() ) ) );
kamalblogs: Setting default object owner as Object creator in Window server 2008 for AIF in Dynamics Ax Blog bot DAX Blogs 1 04.08.2010 14:24
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
gatesasbait: AP Posting fails because of security setup in Dynamics Ax 4 Blog bot DAX Blogs 0 03.02.2009 02:07
Inside Dynamics AX 4.0: Security Coding Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 04:04.
