#9 |
В KB948313 пишут:
SYMPTOMS When you try to import a customization file in Microsoft Dynamics CRM, you receive the following error message: Failed to import entity relationship "<Relationship>": Invalid Argument. ... CAUSE This problem occurs because you did not publish both entities which are part of the relationship. ... Попробуйте опубликовать эти связанные сущности. |
| За это сообщение автора поблагодарили: Yarilo (1). | |
