Это утверждение справедливо для версий < 5.0
Using wildcards and comma-separated range values
Again, the previous example here was using standard syntax, not the special syntax using expressions. It's not possible to modify the above examples to work with wildcards. The above statement applies to AX versions < 5.0 AX 5.0 introduced solution to wildcards - while you still cannot directly use wildcards in ranges, now it supports the 'LIKE' keyword. (AccountNum LIKE "*AA*" || Name LIKE "*AA*") |
| За это сообщение автора поблагодарили: Kabardian (1). | |
