Старый 19.02.2009, 11:52   #14
ZVV is offline
ZVV
MCITP
Oracle
1,006 / 246 (0) ++++++
Итак:
Да, спасибо за пример, он подтвердил высказанные мною выше подозрения:
(в вашем джобе добавил
 info (qbds1.toString());
    info (qbds2.toString());
    info (qbds3.toString());
) для наглядности. Результаты:
оба One2Many:
SELECT * FROM CustTrans
SELECT * FROM CustTable WHERE CustTrans.AccountNum = CustTable.AccountNum
SELECT * FROM Currency WHERE CustTrans.CurrencyCode = Currency.CurrencyCode
 SQL: (CustTrans) SELECT ... FROM CUSTTRANS A WHERE (SUBSTR(NLS_LOWER(DATAAREAID),1,7)=NLS_LOWER(:in1))
ORDER BY SUBSTR(NLS_LOWER(A.DATAAREAID),1,7),SUBSTR(NLS_LOWER(A.INVOICE),1,41),SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,41)
000003_181 -  -  !
000003_181 - 000001_045 -  !
000003_181 -  - BYR !
CustTable One2One, Currency One2Many:
SELECT * FROM CustTrans JOIN * FROM CustTable WHERE CustTrans.AccountNum = CustTable.AccountNum
 SQL: (CustTrans,CustTable) SELECT ... FROM CUSTTRANS A,CUSTTABLE B
WHERE (SUBSTR(NLS_LOWER(A.DATAAREAID),1,7)=NLS_LOWER(:in1)) AND ((SUBSTR(NLS_LOWER(B.DATAAREAID),1,7)=NLS_LOWER(:in2)) AND (SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,41)=SUBSTR(NLS_LOWER(B.ACCOUNTNUM),1,41)))
ORDER BY SUBSTR(NLS_LOWER(A.DATAAREAID),1,7),SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,41),A.TRANSDATE,SUBSTR(NLS_LOWER(A.VOUCHER),1,41)
000003_181 - 000001_045 - BYR !
CustTable One2Many, Currency One2One:
SELECT * FROM CustTrans JOIN * FROM Currency WHERE CustTrans.CurrencyCode = Currency.CurrencyCode
 SQL: (CustTrans,Currency) SELECT ... FROM CUSTTRANS A,CURRENCY B
WHERE (SUBSTR(NLS_LOWER(A.DATAAREAID),1,7)=NLS_LOWER(:in1)) AND ((SUBSTR(NLS_LOWER(B.DATAAREAID),1,7)=NLS_LOWER(:in2)) AND (SUBSTR(NLS_LOWER(A.CURRENCYCODE),1,7)=SUBSTR(NLS_LOWER(B.CURRENCYCODE),1,7)))
ORDER BY SUBSTR(NLS_LOWER(A.DATAAREAID),1,7),SUBSTR(NLS_LOWER(A.INVOICE),1,41),SUBSTR(NLS_LOWER(A.ACCOUNTNUM),1,41)0
00003_181 -  - BYR !
оба One2One:
SELECT * FROM CustTrans JOIN * FROM CustTable WHERE CustTrans.AccountNum = CustTable.AccountNum JOIN * FROM Currency WHERE CustTrans.CurrencyCode = Currency.CurrencyCode
 SQL: (CustTrans,CustTable,Currency) SELECT ... FROM CUSTTRANS A,CUSTTABLE B,CURRENCY C
AND ((SUBSTR(NLS_LOWER(C.DATAAREAID),1,7)=NLS_LOWER(:in3)) AND (SUBSTR(NLS_LOWER(A.CURRENCYCODE),1,7)=SUBSTR(NLS_LOWER(C.CURRENCYCODE),1,7)))
Как видите, запросы к БД отсылаются в этих случаях по разному, как я говорил, вероятно Аксапта "оптимизирует" таким образом сложный запрос.
Насколько я понял, данный эффект происходит только в том случае, когда идёт непоследовательное соединение датасорсов! Только в этом случае Аксапта начинает "оптимизировать" (как в примере, естественно датасорсов при этом всегда больше двух, как вы верно подметили ) и тогда нужно либо указывать fetchMode=One2One, чтоб запрос к БД был один и тогда можно пользоваться стандартным циклом по квериРун, как обычно. Либо добавлять сложные конструкции с проверкой смены "папы" последством record.Changed(). Если же порядок соединения последовательный, то fetchMode никакого влияния не оказывает, можете сами проверить поменяв местами CustTable & CustTrans и прицепив, соответсвенно, Currency ко второму DS.
Вот! Так что будьте осторожны и учитывайте данную особенность!
ЗЫ Ещё из интересных особенностей данного поведения: Аксаптовский SQL-Trace не ловит подчинённые запросы к БД при такой оптимизации. Их можно увидеть только в трэйсе на уровне БД...
За это сообщение автора поблагодарили: sukhanchik (7).
query, queryrun, выборка, запрос (query)
Dynamics AX: QueryRun and Query Objects - Binding operation failed to allocate buffer space Blog bot DAX Blogs 0 03.04.2009 08:05
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Установка условия ИЛИ (OR) в Query Zeratul DAX: Программирование 3 22.06.2006 14:28
Древовидная структура источников данных в Query rumpleteazer DAX: Программирование 7 03.02.2003 15:52
Часовой пояс GMT +3, время: 08:06.
