Старый 16.01.2009, 14:23   #4
mix2ra is offline
mix2ra
Hi, Sorry for using English but my Russian is worse than elementary
I would like to ask if it would be also possible to write to the file an Unicode sign 0x2028 (End of line)
XML would always replace this sign as well as new line sign '\n' with the 0x00
What need to be done in order to be able to write 0x2028 directly to the file.
Is it possible?
We are still using AX 3.0 (I know that in DAX 4 it is possible by using TextIO class)
Any clues?
Thanks!
unicode, xml, кодировка, ax3.0
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Inside Dynamics AX 4.0: The XML Structure Blog bot DAX Blogs 0 04.10.2007 11:20
Inside Dynamics AX 4.0: XML Document Integration Blog bot DAX Blogs 0 04.10.2007 11:20
Часовой пояс GMT +3, время: 12:53.
