Старый 01.12.2008, 22:09   #7
Ievgenii is offline
Ievgenii
Аватар для Ievgenii
111 / 113 (4) +++++
Got it now ;0). Could be related to import/export.
Please make sure that users have profiles defined per company accounts.
1.Go to Administration - Users -> Profile tab -> Select "Same profile in all companies" or define each profile per company.
2.In case no profiles defined - please create them from Administration - Setup -User profiles. The profile is teh connection link between users and Home pages (Role Center) assigned to them.
You can sent screenshots or/and more info on ievgk[dot]microsoft[dot]com, if you won't resolve the issue.
Thx,
Ievgenii Korovin| Dynamics Ax SCM| Microsoft Corp| http://blogs.msdn.com/DynamicsAxSCM/
За это сообщение автора поблагодарили: Dima_Dima (1).
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Microsoft DAX Dev Center Headlines: New Video About the Microsoft Dynamics AX 2009 Developer Experience Blog bot DAX Blogs 0 23.11.2008 12:05
Часовой пояс GMT +3, время: 22:21.
