Старый 11.11.2008, 12:04   #14
Sada is offline
Sada
Программатор
Аватар для Sada
1,450 / 153 (8) ++++++
AX 4
void checkFixSettlement(InventConsistencyCheck_Trans inventConsistencyCheck_Trans)
    InventSettlement    inventSettlement;
    setprefix("@SYS55578");
    while select forupdate inventSettlement
        where inventSettlement.TransRecId == this.RecId &&
              inventSettlement.InventTransCurrency_RU == InventTransCurrency_RU::PrimaryCur
        setprefix(#prefixField(inventSettlement,RecId));
        if (inventSettlement.ItemId         != this.ItemId                  ||
            inventSettlement.InventTransId  != this.InventTransId)
            checkFailed("@SYS67934",'', SysInfoAction_TableField::newBufferField(inventSettlement, fieldnum(InventSettlement, RecId)));
            if (inventConsistencyCheck_Trans.checkFix() == CheckFix::Fix)
                inventSettlement.doDelete();
                inventConsistencyCheck_Trans.updateCorrected();
            else
                inventConsistencyCheck_Trans.updateNotCorrected();
    select sum(QtySettled),sum(CostAmountSettled),sum(CostAmountAdjustment) from inventSettlement
              inventSettlement.Cancelled              == NoYes::No                        &&
              inventSettlement.SettleModel            != InventSettleModel::PhysicalValue &&
              inventSettlement.InventTransCurrency_RU == InventTransCurrency_RU::PrimaryCur;
    if (inventSettlement.QtySettled != this.QtySettled)
        checkFailed("@SYS67938",'', SysInfoAction_TableField::newBufferField(this, fieldnum(InventTrans, QtySettled)));
        if(inventConsistencyCheck_Trans.checkFix() == CheckFix::Fix)
            this.QtySettled = inventSettlement.QtySettled;
            this.doUpdate();
        else
    if (inventSettlement.CostAmountSettled != this.CostAmountSettled)
        checkFailed("@SYS67939",'', SysInfoAction_TableField::newBufferField(this, fieldnum(InventTrans, CostAmountSettled)));
            this.CostAmountSettled = inventSettlement.CostAmountSettled;
            this.doUpdate();
        else
    if (inventSettlement.CostAmountAdjustment != this.CostAmountAdjustment)
        checkFailed("@SYS67940",'', SysInfoAction_TableField::newBufferField(this, fieldnum(InventTrans, CostAmountAdjustment)));
            this.CostAmountAdjustment = inventSettlement.CostAmountAdjustment;
            this.doUpdate();
        else
За это сообщение автора поблагодарили: miklenew (2).
логистика, переоценка
сопоставление оплат клиента, переносов сальдо-поле накладная в общем журнале? Aquarius DAX: Функционал 3 28.01.2009 12:51
InventTransIdReturn и Закрытие склада DenisS DAX: Программирование 15 03.12.2008 09:02
Denis Fedotenko: Новые поля в складских проводках Blog bot DAX: База знаний и проекты 10 24.05.2007 11:57
Как правильно достучаться из InventTrans до даты накладыной NJD DAX: Программирование 6 22.07.2005 20:52
Связь таблиц InventTrans и PurchLine Pustik DAX: Программирование 2 25.11.2004 12:23
Часовой пояс GMT +3, время: 08:09.
