Старый 27.10.2008, 12:28   #1
Сообщение от MikeR Посмотреть сообщение
Это то как раз понятно, просто режет слух. Поэтому и спросил, можно это обозвать по человецки.
По-моему, нормально.
они на этот форму не ходят?
Оффтопик сюда На форуме одни балаболы?
Старый 29.10.2008, 17:42   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Что то тяжко идет производственный модуль
1
The materials are described with item number and consumption, as well as a range of other data used for processing in the production system.
Production BOMs are based on Bills of material from the base data, as the production BOM is generated in connection with Production creation as a copy of a bill of material from base data. In that way, it is the bill of material for the item being produced in production, which is copied to the production BOM. The only exception is if the item has no bill of materials, and no BOM number was given upon its creation. In that case, the production BOM will be blank.
2 Поле Phantom
Is used if items of type BOM are to be exploded in this production bill of materials. When a bill of material is exploded, it creates the raw materials and operations created as base data on the current bill of materials item number.
Explosion is carried out in connection with estimate. You will find more information on estimate in Estimation.
3
If you in the production sequence use subcontractor work for which you want to create a purchase order automatically, use type Vendor.
4
Round using Measurement if raw material is available only with predefined dimensions. If you need to take the above into account when calculating the consumption, use rounding to Measurement and set RoundUpQty to 5. The rounding is calculated by first determining the sales quantity on the basis of the measurement dimensions and then determining the number of times the measurement dimension figure can be included in RoundUpQty The sales quantity is then rounded down to 0 (zero) decimals. Now you can estimate the quantity by calculating how many multiples of the value in field RoundUpQty is to be used in order to produce a given quantity.
5
When you use Rounding-up Consumption the calculated estimated quantity is always rounded so that it can be divided equally with the value of RoundUpQty Rounding-up to Consumption is used when the total consumption of a raw material only can be carried out using a pre-defined quantity and the remainder is then regarded as loss
Axapta book for developer
Старый 29.10.2008, 19:52   #3
2 Поле Phantom
В Аксапте переведено как "Искусстевенный"
У остальных так и переводится "Фантомная спецификация"
Суть - мы создали Фантомную спецификацию (как правило полуфабрикат).
Включили эту спецификацию в другую спецификацию 2.
Когда создается производственный заказ на производство Спецификации 2,
то никогд не создается отдельный производственный подзаказ для производства фантомной, все материалы фантомной просто добавляются в Спецификацию 2 на тот уровень, где была Фантомная спецификация.
Для чего это нужно?
Есть какой-то типовой бизнес-процесс в производстве. В этот бизнес-процесс всегда идут одни и те же материалы/полуфабрикаты, но они никогда не производятся отдельно.
За это сообщение автора поблагодарили: MikeR (1).
Старый 29.10.2008, 21:31   #4
MikeR is offline
MikeR
MCT
Аватар для MikeR
а это что за зверь "subcontractor work" ?
Старый 30.10.2008, 09:50   #5
Работа субподрядчика.
Старый 19.06.2012, 15:30   #6
phas13 is offline
phas13
Аналогичный для Dynamics AX 2009
В теме спрашивали, но никто не ответил: существует ли аналогичный документ для Dynaimcs AX 2009?
Старый 29.10.2008, 21:54   #7
glibs is offline
glibs
Member
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Сообщение от mazzy
IMHO, скорее нет.
Просто в Аксапте под разные варианты исполнения продукции могут создаваться отдельные спецификации. В результате спецификаций получается много. Аксапта в этом проблемы не видит.
Если много спецификаций отличается какой-то мелочью, то лучше создать одну фантомную, и включить ее во все остальные + дельта.
Это облегчает технологам процесс внесения изменения в основную часть спецификации. Иначе им придется много всего отслеживать чтобы изменить норму расхода какого-то материала в основной части спецификации.
С уважением,
glibs®
За это сообщение автора поблагодарили: gl00mie (2).
ax4.0, bi, download, faq, olap, данные, документация, модель данных, полезное, crm2011
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
daxcoder: Microsoft Dynamics ax 4.0 data model overview Blog bot DAX Blogs 2 02.10.2008 19:26
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 15:26.
