Старый 16.05.2008, 14:15   #9
glibs is offline
glibs
Member
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Вот джоб, о котором я веду речь. Писался под 3.0. Но на 4.0, вроде, запускается.
static void findBadRefRecId(Args _args)
UtilElements utilElements;
DictTable dictTable;
DictField dictField;
DictType dictType;
TableName prevTable;
Counter i,
result,
fieldsFound,
tablesFound;
Boolean skipField(extendedTypeId _typeId)
DictType localDictType = new DictType(_typeId);
if (!localDictType)
return false;
switch (localDictType.id())
case typeId2ExtendedTypeId(typeid(recId)) :
case typeId2ExtendedTypeId(typeid(tableId)) :
case typeId2ExtendedTypeId(typeid(ParametersKey)) :
case typeId2ExtendedTypeId(typeid(classId)) :
case typeId2ExtendedTypeId(typeid(FieldNum)) :
case typeId2ExtendedTypeId(typeid(fieldId)) :
case typeId2ExtendedTypeId(typeid(FontSize)) :
case typeId2ExtendedTypeId(typeid(SessionId)) :
case typeId2ExtendedTypeId(typeid(timeOfDay)) :
case typeId2ExtendedTypeId(typeid(Days)) :
case typeId2ExtendedTypeId(typeid(WeekDay)) :
case typeId2ExtendedTypeId(typeid(InventDimFixed)) :
case typeId2ExtendedTypeId(typeid(PrintCopies)) :
case typeId2ExtendedTypeId(typeid(TaxReportField)) :
case typeId2ExtendedTypeId(typeid(JmgSeconds)) :
case typeId2ExtendedTypeId(typeid(Minutes)) :
case typeId2ExtendedTypeId(typeid(Seconds)) :
case typeId2ExtendedTypeId(typeid(Column)) :
case typeId2ExtendedTypeId(typeid(Columns)) :
case typeId2ExtendedTypeId(typeid(Yr)) :
case typeId2ExtendedTypeId(typeid(Months)) :
case typeId2ExtendedTypeId(typeid(NumberSequenceRange)) :
return true;
default :
if (localDictType.extend())
return skipField(localDictType.extend());
return false;
str typesChain(extendedTypeId _typeId)
DictType chainDictType = new DictType(_typeId);
str ret;
if (chainDictType)
ret = ret + strfmt(" --> %1", chainDictType.name());
if (chainDictType.extend())
ret = ret + strfmt("%1", typesChain(chainDictType.extend()));
return ret;
while select utilElements
order by name
where utilElements.recordType == UtilElementType::Table
if (prevTable != utilElements.name)
dictTable = new DictTable(tablename2id(utilElements.name));
if (!dictTable.isMap() && !dictTable.isView() && !dictTable.isTmp())
info (strfmt("%1", dictTable.name()));
tablesFound++;
result = 0;
for (i = 1; i <= dictTable.fieldCnt(); i++)
dictField = new DictField(dictTable.id(), dictTable.fieldCnt2Id(i));
if (dictField.baseType() == Types::Integer &&
!dictField.isSystem() && !skipField(dictField.typeId()))
dictType = new DictType(dictField.typeId());
info (strfmt(" %1 -- %2",
dictField.name(),
dictType ? typesChain(dictField.typeId()) : int2str(dictField.typeId())));
// if (dictType)
// info (strfmt(" %1 -- %2", dictType.label(), dictType.help()));
fieldsFound++;
result++;
if (!result)
infolog.cut(infolog.line());
tablesFound--;
prevTable = utilElements.name;
info (strfmt("Total number of tables found: %1", tablesFound));
info (strfmt("Total number of fields found: %1", fieldsFound));
С уважением,
glibs®
ax3.0, recid, дефрагментирование recid
Как выполнять дефрагментирование RecID mazzy DAX: База знаний и проекты 174 05.10.2017 12:59
Denis Fedotenko: Новые поля в складских проводках Blog bot DAX: База знаний и проекты 10 24.05.2007 11:57
aEremenko: Дефрагментация RecID Blog bot DAX Blogs 2 06.03.2007 22:25
Тип поля RecId Eldar9x DAX: Программирование 4 14.11.2006 16:03
Получить значение поля таблицы по номеру (Id) поля Anais DAX: Программирование 2 15.04.2004 13:00
Часовой пояс GMT +3, время: 05:35.
