Вот код этой выгрузки
X++: static void CustCMRForm_ES(CustInvoiceJour CIJ, CurrencyCode _nCCode='EUR'){ str s; QueryRun queryRun; Query query; QueryBuildDataSource qbdsITrans; QueryBuildDataSource qbdsInventDim; QueryBuildRange qbr; CustInvoiceJour IJour; SalesTable SalesTable; CustTable Vendor,Customer; InventSerial ISerial; CustInvoiceTrans ITrans,ITrans1; InventTrans InventTrans; InventDim InventDim,InventDim1; RContractTable RCT; InventTable ITable; CurrencyCode CCode,nCCode=_nCCode; Address ADR; Amount sSum=0, sVAT=0,wN=0,wB=0,wNl=0,wBl=0; Qty sQty=0; counter i,p,start; counter RollCount=0,PalletCount=0, lRollCount=0,lPalletCount=0; RNumDateInWordConverter converter = RNumDateInWordConverter::construct('en-us'); boolean ExOut=false; #ExcelExport ComExcelDocument_RU excl=new ComExcelDocument_RU(); Str Amount2Text(real Amount, CurrencyCode Curr){ return converter.numeralsToCurrency(Amount,Curr); } Str Qty2Text(real Amount){ return strfmt('%1 kg %2 g',converter.numeralsToTxt( abs(Amount) - frac(abs(Amount))),int2str(decround(frac(abs(Amount)) * 100, 2))); } Str RC(int r,int c){ return ComExcelDocument_RU::numtonamecell(c,r);//strfmt('R%1C%1',r,c); } Str RC_(int r,int c){ return strfmt('R[%1]C[%1]',r,c); } ; converter.initCurrencyAndConnection(); excl.newFile(#ExcelTemplateDir+#ExCMR_ES); // -= ????????? ?????? =- excl.visible(false); IJour=CustInvoiceJour::findFromCustInvoiceTrans(CIJ.SalesId,CIJ.InvoiceId,CIJ.InvoiceDate,CIJ.numberSequenceGroup);// ???? CCode=IJour.CurrencyCode?IJour.CurrencyCode:CompanyInfo::find().CurrencyCode; SalesTable=SalesTable::find(CIJ.SalesId); // ????? Vendor=CustTable::find(SalesTable.JuridicalPerson_NV); // ????????? - ???? ??????????? ???? Customer=CustTable::find(SalesTable.CustAccount); // ?????? p=1; RCT=RContractTable::find(RContractPartnerType::Cust,IJour.RContractCode,IJour.RContractAccount); excl.insertValue('Contract',RCT.RContractNumber,p); // ??????? excl.insertValue('ContractDate',date2StrUsr(RCT.ContractDate),p); // ???? ???????? excl.insertValue('ContractValidityDate',date2StrUsr(RCT.ContractEndDate),p); // ???? ????????? ???????? excl.insertValue('NumberSpecification',SalesTable.ExtNo_Spec_REP,p); // ???????????? excl.insertValue('DateSpecification',date2StrUsr(SalesTable.createdDate),p); // ???? ?????????? excl.insertValue('CustomerAdressIndex',Customer.invoiceAddress().ZipCode,p); // ?????? ?????????? excl.insertValue('CustomerCountryAdress',Customer.invoiceAddress().Country,p); // ?????? ?????????? excl.insertValue('CustomerCityAdress',Customer.invoiceAddress().City,p); // ????? ?????????? excl.insertValue('CustomerStreetAdress',Customer.invoiceAddress().Street,p); // ????? ?????????? excl.insertValue('CustomerHouseAdress',strfmt('%1 %2 %3',Customer.invoiceAddress().Estate_RU, Customer.invoiceAddress().Building_RU, Customer.invoiceAddress().Flat_RU),p); // ??? ?????????? excl.insertValue('Customer',Customer.Name); // ?????????? excl.insertValue('DeliveryPlace',Global_REP::CustExtAdr(Customer,Customer.invoiceAddress()),p); // ????? ?????????? excl.insertValue('DateShipping',date2strusr(IJour.InvoiceDate)/*systemdateget()*/,p); // ???? ???????? excl.insertValue('NumberShipping',IJour.InvoiceId,p); // ????? ???????? excl.insertValue('Amount',Currency::curAmount2CurAmount(IJour.InvoiceAmount,CCode,nCCode),p); // ????? excl.insertValue('AmountStr',Amount2Text(Currency::curAmount2CurAmount(IJour.InvoiceAmount,CCode,nCCode),nCCode),p); // ????? ???????? excl.insertValue('NumberAutomobile',gReport_REP::VehicleNo(IJour));// ? ?????????? i=0; query = new Query(); qbdsiTrans = query.addDataSource(tableNum(CustInvoiceTrans)); qbdsInventDim = qbdsiTrans.addDataSource(tableNum(InventDim)); qbdsInventDim.relations(true); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesId)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,InvoiceId)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,InvoiceDate)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,numberSequenceGroup)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,ItemId)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesUnit)); qbdsITrans.addSortField(fieldNum(CustInvoiceTrans,SalesPrice)); qbdsInventDim.addSortField(fieldnum(InventDim,InventSizeId)); qbdsITrans.orderMode(ordermode::GroupBy); qbdsInventDim.orderMode(ordermode::GroupBy); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesId)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,InvoiceId)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,InvoiceDate)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,numberSequenceGroup)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,ItemId)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesUnit)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,SalesPrice)); qbdsInventDim.addSelectionField(fieldnum(InventDim,InventSizeId)); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,Qty),SelectionField::Sum); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,lineAmount),SelectionField::Sum); qbdsITrans.addSelectionField(fieldNum(CustInvoiceTrans,lineAmountTax),SelectionField::Sum); qbdsITrans.addRange(fieldNum(CustInvoiceTrans,SalesId)).value(CIJ.SalesId); qbdsITrans.addRange(fieldNum(CustInvoiceTrans,InvoiceId)).value(CIJ.InvoiceId); qbdsITrans.addRange(fieldNum(CustInvoiceTrans,InvoiceDate)).value(queryvalue(CIJ.InvoiceDate)); qbdsITrans.addRange(fieldNum(CustInvoiceTrans,numberSequenceGroup)).value(CIJ.numberSequenceGroup); queryRun = new QueryRun(query); while (queryrun.next()) { ITrans=queryrun.get(tablenum(CustInvoiceTrans)); InventDim=queryrun.get(tablenum(inventdim)); // select * from ITrans where ITrans.SalesId==CIJ.SalesId && // ITrans.InvoiceId==CIJ.InvoiceId && // ITrans.InvoiceDate==CIJ.InvoiceDate && // ITrans.numberSequenceGroup==CIJ.numberSequenceGroup { wNl=0;wBl=0;lRollCount=0;lPalletCount=0;ITable=InventTable::find(ITrans.ItemId); while select * from ITrans1 where ITrans1.SalesId==ITrans.SalesId && ITrans1.InvoiceId==ITrans.InvoiceId && ITrans1.InvoiceDate==ITrans.InvoiceDate && ITrans1.numberSequenceGroup==ITrans.numberSequenceGroup && ITrans1.ItemId==ITrans.ItemId && ITrans1.SalesUnit==ITrans.SalesUnit && ITrans1.SalesPrice==ITrans.SalesPrice { while select sum(Qty) from inventTrans join inventdim1 group by inventserialid where inventtrans.inventDimId==inventdim1.inventDimId && inventtrans.StatusIssue==StatusIssue::Sold && inventtrans.InventTransId==iTrans1.InventTransId && inventtrans.ItemId==iTrans.ItemId && inventdim1.InventSizeId==inventdim.InventSizeId { RollCount++; lRollCount++; } while select sum(Qty) from inventTrans join inventdim1 group by wmspalletid where inventtrans.inventDimId==inventdim1.inventDimId && inventtrans.StatusIssue==StatusIssue::Sold && inventtrans.InventTransId==iTrans1.InventTransId && inventtrans.ItemId==iTrans.ItemId && inventdim1.InventSizeId==inventdim.InventSizeId { // wB=wB+WMSPallet::find(InventDim.wMSPalletId).GrossWeight_NV; // wBl=wBl+WMSPallet::find(InventDim.wMSPalletId).GrossWeight_NV; PalletCount++; lPalletCount++; } // while sum(qty) } // while ITrans1 wN=wN+ITrans.Qty; wNl=wNl+ITrans.Qty; wB=wB+ITrans.Qty*1.04;//WMSPallet::find(InventDim1.wMSPalletId).GrossWeight_NV; wBl=wBl+ITrans.Qty*1.04;//WMSPallet::find(InventDim1.wMSPalletId).GrossWeight_NV; //invoice start=32;p=2; excl.insertRow(start+i,p); excl.insertValue(RC(start+i,1),int2str(i+1),p); excl.insertValue(RC(start+i,3),strfmt('%1 ? %2 (BOPP coex)',ITable.ItemName,inventDim.InventSizeId),p); excl.insertValue(RC(start+i,17),ITrans.SalesUnit,p); excl.insertValue(RC(start+i,22),ITrans.Qty,p); excl.insertValue(RC(start+i,28),Currency::curAmount2CurAmount(ITrans.SalesPrice,CCode,nCCode),p); excl.insertValue(RC(start+i,33),Currency::curAmount2CurAmount(ITrans.LineAmount+ITrans.LineAmountTax,CCode,nCCode),p); //detail packing start=24;p=3; excl.insertRow(start+i,p); excl.insertValue(RC(start+i,1),int2str(i+1),p); excl.insertValue(RC(start+i,3),ITable.ItemGroupId,p); excl.insertValue(RC(start+i,7),'',p); // ???? ? ?. ?. - ?????? ????? ???????? - ?? ???????????? ??????? (??????? ??????) ?? ????????? excl.insertValue(RC(start+i,13),ITable.ThicknessId_NV,p); excl.insertValue(RC(start+i,17),inventDim.InventSizeId,p); excl.insertValue(RC(start+i,21),lRollCount,p); excl.insertValue(RC(start+i,25),lPalletCount,p); excl.insertValue(RC(start+i,29),ITrans.Qty,p); excl.insertValue(RC(start+i,34),wBl,p); //Form A // start=32;p=4; // excl.insertValue(RC(start+i,9),strfmt('%1 ? %2 (BOPP coex) - %3 %4',ITable.itemName,inventDim.InventSizeId,iTrans.Qty,iTrans.SalesUnit),p); // excl.insertValue(RC(start+i,24),'\"W3920\"',p); //Attent start=19;p=6; excl.insertRow(start+i,p); excl.insertValue(RC(start+i,1),int2str(i+1),p); excl.insertValue(RC(start+i,3),strfmt('%1 ? %2 (BOPP coex)',ITable.itemName,inventDim.InventSizeId),p); excl.insertValue(RC(start+i,19),ITrans.SalesUnit,p); excl.insertValue(RC(start+i,21),ITrans.Qty,p); i++; } excl.insertValue('Currency',nCCode,p); excl.insertValue('RollCount',RollCount,p); excl.insertValue('TotalPallet',PalletCount,p); excl.insertValue('WeightNetto',wN,p); excl.insertValue('WeightNettoStr',Qty2Text(wN),p); excl.insertValue('WeightBrutto',wB,p); excl.insertValue('TotalPackages','???? ??????!!!',1); // excl.insertValue('sQty',sQty); // excl.insertValue('sVAT_',sVAT); // excl.insertValue('sSum_',sSum); // excl.insertValue('sSum',Amount2Text(sSum,IJour.CurrencyCode)); // ????? ???????? // excl.insertValue('sVAT',Amount2Text(sVAT,IJour.CurrencyCode)); // ??? ???????? excl.visible(true); } |
